Some of them are getting MPSC2s
Just got an update that mine is at the port in Emden awaiting a shipping vessel. The tracking system shows my vin and Michelins for tires.
Not that the contis are bad as I haven't used them, but I do like the Cup2s I have used so I'm happy.
Congrats. I wonder how they choose what tires to put on what car? My GT3 came with the Dunlops.
When is your car scheduled to arrive? I'd love to see it. Mine is scheduled to arrive at the end of Aug/beginning of Sept.
Cheers,
Rob
Cheers,
Rob
Congrats, great tires!
The dunlops have been good on the street so far. Only had a couple sessions on track with them and the fronts are wearing the center rib pretty fast. Need to figure out if that's pressure (starting pretty low), a different center compound, or I'm asking too much of the front end.
My Spyder has MPCS2's and the jury is still out on them, although them seems to be wearing better than the Dunlops.
I'll be at Chin as well and have a couple spots open in my garage if you want to join?
I won't get mine until early next year, so I'm hoping by then early owners will have come to a consensus on optimum track tire pressure. Judging by the GT3 threads, it seems cold pressures in the 29-31 range may be appropriate, which is lower than I'm used to, but I guess my M3 is several hundred pounds heavier.
Out of curiosity, what hot pressures are you targeting? And approximately what cold pressures do you need in order to hit those numbers? Typically if the center is wearing faster it means that pressures are too high due to how tire shape changes with pressure.
With the dunlops I'm having to start in the mid-twenties to hit mid-thirties. My thought maybe that I'm going to hard to early and the tire is deforming with the low pressure. My first session I started around 28psi and ended up close to 40psi at the end of the session so I went down in pressure for the second session.
Yes Sir, you are correct about high pressure. It's not the entire center rib wearing, but a bevel in only the center rib. One other tire I've seen do that is the Bridgestone RE71R.
Fwiw, proper hot pressure on Cup tires, which I know you're not running, is 34-36 PSI according to Michelin and apparently just 29-32 PSI (!!!) according to some GT3 owners.
That wear in the middle of the Dunlops is interesting, I wonder if that is a tire mold seam that is separating?
Michelin recommendation. Start there and adjust. 997 GT3/RS works well with those numbers.
