Sponsored by: APR
Best 19” Track Tire Options for GT4
Old 09-19-2022 | 03:10 PM
Emosgarage's Avatar
Emosgarage
Default Best 19” Track Tire Options for GT4
I have a set of 19” Apex wheels on my GT4 (9.0”/10.5”). No suspension mods/camber plates. I just burned through a set of Yokohama AD08R’s in 255/35 and 295/30.
I need a replacement tire, but supplies are limited in that front tire size. I’m thinking about going with a 235/35 in front. That would make the front OD about a half inch smaller than the rear, but opens up more tire options. My current setup is equal diameter front to back.
Two questions: (1) Any concerns about the 1/2 inch smaller OD up front? and (2) any recommendations on a tire that would be more aggressive than the AD08R and available in these sizes? I can’t find Hoosiers for example in these sizes. The Toyo Proxes RR appears to be an option.
Thank You!
Old 09-19-2022 | 05:37 PM
85Gold's Avatar
85Gold
Lots of 19" choices, Kuhmo V730 245/35 305/30, Falken RT660 245/35 305/30, Bridgestone RE71RS 245/40 285/35, Nankang CR-S
Peter
The following 2 users liked this post by 85Gold:
Emosgarage (09-20-2022), WillyDaP (02-25-2024)
Old 09-19-2022 | 05:59 PM
GeoJoe's Avatar
GeoJoe
Pirelli DH by far
Old 09-20-2022 | 12:44 PM
Montaver's Avatar
Montaver
AD08r are ancient, I believe they have been superseded by AD09r. There are tons of options for arrive and drive in similar ballpark- RE71RS, Cup2's, Goodyear SC3, RT660, Yoko A052's (stickiest but least durable of this list). I would try 265/295 RT660's and see how you like them. You could also give RE71RS a shot although not many reviews yet. To run 265's up front you may need camber plates, although if your tracking a lot its a no brainer to put them in. Tarrett plates are very good. For stickier options you can run Hoosiers in 265/295 (need to trailer), or Goodyear SC3R (DOT legal but you are stuck if it rains). You could also run 245/295 Hoosiers on stock 20" wheels with no camber mods.
Old 09-20-2022 | 02:32 PM
Emosgarage's Avatar
Emosgarage
thank you to everyone who responded. I’m going to check out the 245/295 Hoosier setup, since I don't have camber plates installed but do trailer the car. Appreciate the feedback!
Old 09-20-2022 | 03:37 PM
9eight7's Avatar
9eight7
What's up Emos! (I follow you on IG). I have the RT660 and like them quite a bit for track, street, and rain.
Old 09-20-2022 | 04:15 PM
Emosgarage's Avatar
Emosgarage
hey! thanks for finding me here! good to know about the RT660. I have those on our Daytona kit car that we are building, actually. I think I will try the Hoosiers since I have a separate set of wheels for street driving. Although, in the
19” size they don’t offer a 245 width, so I’d have to run a 235 on 9” wheel, which looks like it will work from the specs I’ve researched.
Old 09-29-2022 | 09:28 PM
Jim Cobb's Avatar
Jim Cobb
FWIW, Based on only a few track sessions, I’d say the RE-71rs are at least as grippy as their predecessor. They are supposedly more durable as well, but that remains to be seen in my case.
Old 09-30-2022 | 02:09 PM
vantage's Avatar
vantage
Would hesitate to run 235s especially if you don't have a track alignment. Front grip will already be limited.
RobC4sX51 (11-27-2023)
Old 10-02-2022 | 05:44 PM
destroid's Avatar
destroid
Cup2 is available 265/35 19 (it's an M0 spec according to Tirerack)
I have 9.5 x 19s up front currently with RE-71R in 265/35 19 and the Cup2 will be my replacement.
Old 10-02-2022 | 08:05 PM
Five12Free's Avatar
Five12Free
the RT660s run wide, so make you get the actual measurements.., especially out back
Old 11-14-2022 | 10:20 PM
125shifter's Avatar
125shifter
Time to buy new track tires for the 19” x 9 & 10” wheels on my ‘14 cayman s. I tried cup 2’s in 245/35 and 275/35 but really chewed up the front tires. I’ve just installed Ohlins R&T coilovers, GT4 sway bars, front lower arms and rear toe links so I could set camber to 2.5 front and 2.0 rear. Hopefully this helps with tire wear.
I picked 245 & 275 tires since that looked right for 9&10” wheels but I see many GT4 drivers running 255 & 285 tires on the same width wheels. Does the additional tire width make up for less than optimal tire to wheel sizing?
planning to try RE-71RS tires
Old 11-15-2022 | 12:18 PM
Scott O'Connor's Avatar
Scott O'Connor
Nankang AR-1's are on mine and I like them. 275 and 305.
Old 11-18-2022 | 02:02 PM
Snowy999's Avatar
Snowy999
Yoko A052 are excellent.
I run 295 35 (27.2") and 255 35 (26").
Bit more rake and obv lower at front.
I wasn't able to get the 265 40 which would have got the car riding at standard height plus or minus.
Great grip, great early laps, good in wet/damp but wears fast.
Old 11-18-2022 | 08:33 PM
ALE's Avatar
ALE
981 GT4 with rim sizes: 19x9 & 19x10.5
Last weekend we gave the Falken RT 660s a go; as many have stated, it's a good tire with terrific grip - felt better than the GY SC3 200TW. They are a little vague, but provide excellent grip.
Only negative is that they don't make a 295/30/19; thus, we tried the 295/35/19 with 265/35/19 up front.
The rear tires quickly had a polished ring at the top of the sidewall, where it rubbed the fender lip (see picture). Stock springs, but with a track alignment and rear toe links.
Not dangerous, but not ideal either.
While the Falken 305 rear width is a 30 height, I'm concerned that they will rub the tread, which could be dangerous.
Eager to hear back from anyone after they run the Bridgestone RE71RS 255/35/19 & 285/35/19 on my rim sizes with a 981 GT4.
Thanks RL!
