Pinion Gear Failure
Pinion Gear Failure
Hi all. I was having my LSD inspected with a view to overhaul it if required and my guys found the pinion gear is useless after multiple teeth are pitted. Has anyone else heard of this? The car has 25,000 kms on it. I am asking my local Porsche dealer if they can help out.
Following.
My trans is making a noise that is indicative of a wearing final drive; gonna get it into DeMan soon to have it looked at. From what I understand, Porsche doesn't sell ring & pinions separately—only complete gearboxes—so I've been keeping an eye on all the various auction sites to see if there are any low mileage G81.20 boxes up for sale (my car's at 67500 mi / 108630 km, for reference)
Following.
What does that sound like?
My techs have researed the failure and it is called "spalling". It results from a problem with the heat treatment/case hardening during manufacture. It usuall effects only pinion gears and not ring gears (my ring gear is in perfect condition). I have asked my Porsche dealer to help out as it is a failure that should not happen.
And yes it's true that Porsche will not sell the RPG set only complete boxes. But will they will sell reconditioned boxes; at about 2/3 the price of a new box. I guess they have a lot of recond boxes after the 3rd gear recall campaign.
That sux Warwick. Coincidentally just this week my gearbox started making a horrible rattling sound at low rpm and in any gear. My porsche guy had a stethoscope on the box and its definitely inside the box however no metal filings in the gear box oil. Porsche wont warrant it or offer spares
I may have to look at some GTgears stuff
That spalling doesn't look pretty - it looks worse than Warwick's pinion gear teeth. And you say you didn't find any metal filings in the oil. If you didn't, I'll bet that the case hardening has been ground up to dust and distributed through the whole transmission & bearings ....
How many km on the gearbox and what lubricant have you been using?
Sorry to hear that mate. There appears to be no reasonable economic fix; and I've tried everything and searched globally. A used box is of course an option but may end up having the same problems. I'll probably buy a recond box from Porsche which comes with a 2 yr warranty.
