BBi Autosport White Porsche GT4 Track Prep Roll Bar Install
Basic Sponsor
Attachment 1335528
Featured Install ➡️ We installed our BBi Autosport StreetCup Roll Bar / Schroth Racing Harness Safety Package for increased protection and proper restraint, and the was powdercoated in Gloss White to match the exterior. We have these bars in stock uncoated ready to be powdercoated or painted in any color. New dealers are weclomed and we ship worldwide!!! Here are some pictures that we would like to share below.
Vehicle Specifications
BBi Autosport GT4 Safety Package Install
BBi Autosport GT4 Roll Bar
BBi Autosport Sub-Belt Brackets
Bar & Harnesses Installed
Finished Project
BBi Autosport 981 GT4 StreetCup Harness Bar
Key Features
BBi Porsche 991 GT3/ GT3RS / Cayman GT4 Sub-Strap Mount
When equipped with optional Sport Bucket seats, this bracket is required to install 6-point race harnesses. This bracket bolts directly to the seat and keeps the harnesses at the proper 10-20° angle regardless of the seat position.
Features
Product Link ➡️https://www.bbiautosport.com/product...b-belt-bracket
BBi Harness Install Kit
BBi Harness Install Kit included extended bolts to properly accommodate both the OEM seat belts and racing harnesses at the factory mounting locations on the 991 GT3 / 981 GT4 Sport Bucket Seats . This kit features metal sleeves fitted around the bolts so that the belt brackets can pivot freely on the bolt. Sold as a kit per seat.
Product Link ➡️https://www.bbiautosport.com/product...at-991-981-gt3
- Jerry@BBiAutosport.com
- BBi Autosport StreetCup Roll Bar
- BBi Autosport Sub-Belt Brackets
- BBi Autosport Harness Bolt Kits
- Schroth Racing Harnesses
Finished Project
Key Features
- Chrome moly steel tubing utilized for excellent strength to weight ratio
- Modular construction to allow access to engine for servicing without removing entire roll bar
- Shoulder harness mounting crossbar positioned at appropriate height as per Schroth's instructions
- TIG welded and utilizes "X" braces on rear section for superior strength and rigidity
- Mounts to frame structure and rear strut tower to provide strongest mounting points and maximum protection
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
- Designed to work with stock or any aftermarket seats on the market
- Minimal effect on seat travel to accommodate taller drivers
- Can be used with stock seat belts or 6 point harnesses for track use
- Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
- OEM fit & finish. The main hoop contours entire arch of the roof with an even curve
- Finished in satin black powder coat. Other colors available
- Bolt-in installation requires no drilling and minimal carpet trimming
Features
- Provides mounting location for sub-belts at the proper 10-20° angle regardless of the seat position
- Precision CNC laser cut and bent from one piece high carbon steel for superior strength
- Stylish design with laser cut BBi logo and durable satin black Powdercoat finish
- Attaches to seat assembly using factory mounting points with all hardware included
- Compatible with Porsche 991 GT3 and 981 Cayman GT4 models equipped with Sport Bucket Seats
- Made in the USA
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Great bar with perfect fitment. Not sure how much it weighs but they're all about the same for these cars. I was able to install it myself with without any help.
Thanks, what is the harness bar height like? I thought maybe it would be a little high for some seats? Thinking of going with the Recaro Profi SPG.
I had a BGB bar previously (came with the car) that had the harness bar that goes over the center trim/carpet instead of through. That bar was far too high. That spurred my decision to purchase the BBi bar after doing a ton of research.
It's at the right level for me, I'm 5'6 with LWBs at nearly full low setting using the lower harness slot in the seat. The harnesses sit level with my shoulders with a neck restraint. I'm probably on the low end of driver height distribution, so the harness bar height should be fine for all applications.
What is it like for visibility out the back noting I don't have a rear wing on my car? Also there are lots of trim pieces to cut. I notice some suppliers offer a trim kit and just wondering what the cost is for the trim parts? That rear carpet piece looks quite a lot to replace if you wanted to reverse the mod.
I guess my only other concern is whether or not there is any issues with servicing and engine access from the top with the cross bracing in the way?
Thanks, the harness bar height does sound good and it looks like a really solid bar with the cross bracing. I regret not getting a car with the LWBs.
The X can be removed for servicing relatively easily. 4 bolts and you're done, although I would probably remove the shock tower parts as well since it all needs to come apart for the cover to come out anyway.
donR (11-04-2020)
