OEM Wheel Defect
Old Jun 7, 2019 | 08:18 AM
d00d's Avatar
d00d
Originally Posted by jmartpr
My Solution, at least for the track...get a good set of forged Wheels in 19"....stronger, less weight and a bit more sidewall so you feel a lot better going over those berms....Ohh and get back those 0.5" the GT3 guys get and we don't.
And possibly less stress on the towers.
Old Jun 7, 2019 | 11:33 AM
sonorous's Avatar
sonorous
Here is another similar thread for reference: https://rennlist.com/forums/gt4/9809...-uploaded.html
Also FWIW, cast and flow formed wheels are also sometimes referred to as "roll forged" which can add further confusion...
Old Jun 7, 2019 | 12:51 PM
Diablo Dude's Avatar
Diablo Dude
This is what makes this community so great!
Everyone is on top of things and not a single grain of sand goes through the hourglass, unnoticed.
Old Jun 7, 2019 | 01:59 PM
trkshoe's Avatar
trkshoe
What was the verdict in the Bahrain wheel... thread just goes dead...
Old Jun 7, 2019 | 02:29 PM
sonorous's Avatar
sonorous
Not a whole lot of information in this one but another post and reported failure for reference: https://rennlist.com/forums/gt4/1139...-failures.html
Old Jun 7, 2019 | 03:50 PM
aigle836's Avatar
aigle836
From: Québec, Quebekistan, Magic Kingdom of Trudeauland
Originally Posted by johnsopa
Small claims court. I'd be surprised if Porsche sent anyone...
Yes but I am in Quebec and Porsche is located in Ontario, Would have to go to small claims in Ontario. In Quebec would have to take the dealer...
But I am pretty sure I would win in Small Claims Court.
Old Jun 7, 2019 | 03:52 PM
aigle836's Avatar
aigle836
Originally Posted by d00d
Could it be that the rim made contact with a serrated berm through the tire, causing the damage, so that when the tire was replaced it had become deflated because of the crack?
No everything was in good condition when they removed the old tire. Not the first time I get the tires changed, but this time everything was fine until then put the pressure on to inflate the tire...
Old Jun 7, 2019 | 03:56 PM
aigle836's Avatar
aigle836
Originally Posted by Viperguy324
Positive this has happened before... Same situation, gator marks on barrel... Go out with more air next time, and stay away from berms until up to temp/pressure.
Did not happen on the track. It's when they inflated the new tire that the wheel imploded instead of the tire "popping" and having the edge of the tire sit against the rim. They then remove the new tire and it's still in perfect condition...
Old Jun 7, 2019 | 04:57 PM
d00d's Avatar
d00d
Yeah, the other thread also indicated over pressure as the cause.
For secondary confirmation, who wants to inflate the tire until their wheel Montblancs?
Then perhaps see if the wheel blends. ;)
Old Jun 7, 2019 | 10:22 PM
BryanCO's Avatar
BryanCO
If this happened at a Porsche dealer, I bet it would be covered. But since it was a third party tire shop, who knows the exact circumstances of the failure and, hence the denied warranty claim.
Old Jul 2, 2019 | 11:35 PM
Bruce H.'s Avatar
Bruce H.
Aigle836,
One of my '19 OEM Turbo S forged wheel barrels buckled like this when installing MPSC2 tires by a reputable shop a couple of weeks ago. Wheel didn't crack, just buckled in several places around the barrel. Got the call today that it isn't being covered and the service advisor is going to see what he can do. I've had dozens of 30 and 35 aspect ratio tires installed on various wheels and never had a problem so it doesn't make sense to me that it could be installer error when they do Porsches constantly. How do you know, how can you prove...and shouldn't Porsche have to demonstrate that the failure was from installer over filling?
Bruce
Old Jul 3, 2019 | 02:45 AM
kmmalek's Avatar
kmmalek
I recall seeing a (tire) manufacturer's warning that the tire max pressure should not be exceeded, even for the purpose of seating the bead on the rim ("popping the tire" as the OP put it.) That max pressure is 50 or 51 psi. Could this damage have resulted from 50 psi only?
Old Jul 8, 2019 | 05:47 PM
Auto_Werks 3.6's Avatar
Auto_Werks 3.6
Quit Smokin'
Yes evenly spaced all around the wheel.
Three evenly spaced failures around the barrel sounds to me like too much pressure was exerted using the 3 jaw clamp while removing the old rubber. The material had already yielded, and then failed when the air pressure applied to seat the bead. If I had to guess.
