Pccb. Unbalance front/rear wear
Hello everyone.
I am about to buy a GT4 equipped with ceramic brakes.
I wondered if it was normal that the rear pads were more worn than the front?
What would be the cause?
traction control?
Based on your experiences, what is the average lifespan of a set of pads?
This for try to judge the use of the car.
Thank you for your return
traction control?
Originally Posted by VincentBul
what kind of conclusions can we make about the driver with this kind of wear
Rears last on average 2x longer than front pads.
That being said, prior driver competence shouldn't preclude from buying the car as long as it wasn't crashed
We've had a lot of discussion on this on GT3 forum. Conclusion is that there is electronic interference in the rear - possibly from the emergency brake. It's not wear, it's a false signal. If you pull the rotor off the hub, you get a completely different metal content measure in the PCCB rotor.
Here is what i found on the Pistonhead's forum:
For those of you with PCCB brakes on your GT4.......
1) After washing the car, give a quick dab on the brakes as they don't work straightaway
2) Check them regularly for signs of chips, cracks and de-lamination
3) Make sure you use the provided long bolts (when removing the wheels from your car) that ensure the wheel will not drop or touch the carbon discs
4) Check the rear brake pads often and replace at 50% worn (the rear brakes are used as a stty replacement for a decent LSD)
5) If tracking the car, turn off traction control as it will overheat the discs (see point 4 above)
6) Look into getting some rear brake cooling ducts to mitigate points 4 and 5 (I have the cooling ducts from the GT3 RS on mine)
