Front Camber setup
Old Jun 21, 2018 | 01:04 AM
DC640's Avatar
DC640
Originally Posted by pkh
I am using plates, shims and tarrets bits and was able to achieve 3.7 front (3.0 rear) ... I was running 3.2 before the GT3 shims. Tires were still wearing a bit on the outside before so I am excited to give this new alignment a try tomorrow.
Those are some manly camber numbers
Old Jun 21, 2018 | 08:04 AM
jmartpr's Avatar
jmartpr
Originally Posted by fastauto
I really want to stay away from the shim route. I just want a plate that can push me over -3. For this, do you think Tarett is the better route?
Not sure on that one....Using the stock LCAs inners and the maximum amount of shims + camber plates all the way inboard my car get between 3.5 and 3.6 negative up front. Before that it was 2.4-2.5 negative with just shims. So a solid -1 degree just from plates.
You would have to measure no shims, stock plates all the way inboard...then add the -1 degree of the camber plate. IMO I don't think you will get there without the shims.
And if you do go over -3 degrees shims+ plates also factor in the tension rods and LCAs solid bushings for the tension rods to bring caster back to more acceptable levels.
Old Jun 21, 2018 | 02:54 PM
fastauto's Avatar
fastauto
Noted and makes sense. Thank you!
Old Jun 23, 2018 | 09:39 PM
pkh's Avatar
pkh
haha thanks! I was real happy with this new alignment - yielded conistent grip throughout sessions despite some really haggard tires.
Old Jun 26, 2018 | 06:42 PM
RaceDevelopementCenter's Avatar
Basic Sponsor
Please don't forget that different tire compounds are going to require or should I say tolerate different alignment settings. Keep that in mind when determining your numbers.
Old Jun 27, 2018 | 11:38 AM
Klepper's Avatar
Klepper
Just adding Tarett camber plates got me to -2.7 on the front (with stock # of shims on the LCA's)
Old Jun 28, 2018 | 03:52 PM
fastauto's Avatar
fastauto
Perfect. TY.
Old Jun 29, 2018 | 10:04 AM
PorscheAddict's Avatar
PorscheAddict
What caster are you all running, for those with adjustable pucks?
Old May 30, 2021 | 10:56 AM
Vidz's Avatar
Vidz
Hi Bill, do you remember if you were able to maintain OEM caster angle with the Rennline camber plates?
Old May 31, 2021 | 07:10 PM
Bill Lehman's Avatar
Bill Lehman
I checked my last alignment and averaged 7.6 degrees caster.
Old Jun 2, 2021 | 10:46 AM
Vidz's Avatar
Vidz
Thanks Bill. So I guess the plates reduce caster by quite a bit
