transmission fluid change interval
I can see why you would want a shop to do the clutch side because of the PIWIS fill procedure, and no harm with that if the shop you use knows what they are doing and has a PIWIS that they will actually bother with using. IMHO, the PDK clutch side fluid is easy to change and can be done without a PIWIS. Drain, fill till it comes out, put in fill plug. Start the car and let the engine idle, hold the clutch fluid cooler pipe until it gets warm (About 3 to 5 min), remove fill plug and top off till fluid runs out again. It is about as simple as the gear oil. You can refer to the planet 9 link previously in this thread and or watch the youtube video on the process if you decide to DIY the clutch fluid as well. Good luck.
Jeff
Jeff
