anti photo laser shield/spray
has anyone used either stuff and how effective is it? is one better than the other? i live in ny and therefore have to put fronts on but as i await the mounting bracket, i was told a cover or even a frame wouldn't take as there is only room for the plate itself.
either way, your experiences along with brand recommendation would be appreciated. thanks.
RL Technical Advisor
'Tis a big scam,.....![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I bought several like products all with "guarantee's".
After coating the plate by strictly following the directions, I took some photos with my Nikon gear (film) using an SB-20 flash. Several pics were shot from 3 angles on each side as well as directly behind and in each case, the plate numbers were clearly visible on the prints.
Oregon, like most states, use plates with reflective backgrounds so the numbers are highlighted at night and for photo radar as well as Laser.
Unless you have non-reflective plates, save your money.
I believe the plastic covers that obscure half the plate from different viewing angles actually do work. They use a sligthly convex shaped lens to block out part of the plate when viewed from the opposite side. I do not have one but I have seen them on cars and even to the naked eye they were obscured.
I always figured that a couple of tiny flash heads, built into the plate frame, would be a good solution.
They trigger when the flash from the speed camera goes off, flooding the plate with with enough light to over expose it.
Technology already exists in the flash world, as this is how studio flash units trigger when they 'see' a flash go off.
Anyone ever seen this idea on a car?
Chris.
Chris.
![](http://www.d30-images.com/911/sig-strip.jpg)
I don't know about where you are but here in Texas, ANYTHING on your tag is a huge BUST. Even frames if they happen to obscure any of the design. (or however the officer wants to interperet it) So be especially careful using ANYTHING designed to defeat photo enforcement. Think car siezure.
Be careful,
Deano
Be careful,
Deano
Check out these two articles:
They provide test results that show the "Laser Veil" product to reduce laser speed detection acquisition range by as much as 60%. This will not help you against photo radar, however. Other laser countermeasures are also discussed, including active jammers which, unlike radar jammers, are entirely legal.
I hope this is helpful.
Dave
Dave
