991.2 Carrera T vs. Carrera S
Hi everyone. I am deciding between picking up a 991.2 Carrera T or a 991.2 Carrera S and I wanted to make sure I fully understood the differences between the two models (assuming similar options such as the 10mm lower ride height, rear-wheel steer, etc.). Here are the differences that I know of:
Anything else that I am missing? Thanks so much guys. Really appreciate the help.
- Horsepower - Carrera S has 420 vs. Carrera T at 370
- Weight - Minimal (~11 lbs) but Carrera T saves weight on 1) less sound insulation 2) fabric door pulls and 3) lightweight glass
- Brakes - Carrera S has 6 piston front brakes vs. Carrera T has 4 piston front brakes. Rear brakes are the same
- Manual Transmission
- Carrera T has a short shifter. Is this different than the Carrera S?
- Carrera T has a mechanical limited slip rear differential. Is this different than the Carrera S?
- I know the Carrera T has a different final drive ratio than the Base but is this different than the Carrera S?
