E/SIM Racing For discussion and info on iRacing, SIMs etc.
Rennlist iRacing thread
Old Apr 3, 2014 | 09:22 PM
  #4201
Sysgen's Avatar
Sysgen
I'm in
Old Apr 3, 2014 | 09:50 PM
  #4202
pmason's Avatar
pmason
When are you starting? Just finished my MX5 race, and did some quick laps at Long Beach, I product this is going to be a mess.
Old Apr 3, 2014 | 09:52 PM
  #4203
Sysgen's Avatar
Sysgen
That tight airpin is crazy ! Looks a lot like Trois-Rivieres
Old Apr 3, 2014 | 09:55 PM
  #4204
JustinL's Avatar
JustinL
I'll host one right away.
Old Apr 3, 2014 | 09:59 PM
  #4205
JustinL's Avatar
JustinL
practice is up now under hosted.
Old Apr 3, 2014 | 10:09 PM
  #4206
pmason's Avatar
pmason
Yea I didn't know there was going to be a 3 point turn in this track :-)
Old Apr 3, 2014 | 11:10 PM
  #4207
abqautoxer's Avatar
abqautoxer
Interesting track, another autocross.
Old Apr 4, 2014 | 12:47 AM
  #4208
NVR2OLD's Avatar
NVR2OLD
This was the first time I have driven it, I think set-up will be important it is a little bumpy. Better qualify well good luck passing
Old Apr 4, 2014 | 09:39 AM
  #4209
User 52121's Avatar
User 52121
I dig it! Though it seems like there is a certain pace that, once you cross it, the track gets sketchy. I can run in the 19.9-20.4 all day long but once I start to push just the tiniest bit more, I get all out of shape. Bumps and crests in the pavement kick the car around quite a bit once you pick up the pace. I managed to squeak a 19.3 but have no idea how Tom got down to 18.0....
With most of the hard-braking, 90-degree turns, I think passing will be fairly easy... though they'll all be "stuff" moves.
Old Apr 4, 2014 | 09:40 AM
  #4210
abqautoxer's Avatar
abqautoxer
I'm using Justin's Sonoma setup and I think it works well allowing me to put down power well out of the slow corners. The final hairpin is a huge sacrifice complex where I give up the 2 previous turns to enter that one with 2 tires on the left rumble strip to make the angle less than 180 and slow way early. Don't get too close to the center wall at apex as it has a curb that really screws you up.
Old Apr 4, 2014 | 09:53 AM
  #4211
User 52121's Avatar
User 52121
I might have to try that setup. I've been using my Sebring setup (which I'm pretty sure is largely based off of one of your sets)
Old Apr 4, 2014 | 10:09 AM
  #4212
abqautoxer's Avatar
abqautoxer
FWIW all my sets were either Ted, Julian, or Justin sets slightly modified to my taste. I think this Sonoma set works well with lower grip and bumps better than the Sebring one we started with so I think you'll find it helps. I'll share it Sunday night if I get back in time from the two day out of town autocross I'm heading to straight from work today.
Old Apr 4, 2014 | 10:50 AM
  #4213
JustinL's Avatar
JustinL
One of the fast guys coughed up a setup last night that I saved. I finally got down to the low 18s with it. I don't yet feel like I can attack the track, more like just hanging on for dear life.
Old Apr 4, 2014 | 10:54 AM
  #4214
abqautoxer's Avatar
abqautoxer
Nice. I'd be curious if it was better than yours for my driving style.
There is a ton of off camber where I roll into the throttle with steering wheel completely straight knowing I want to turn because the throttle is going to take care of it. I got a lot of it wrong at times and knocked my toe out of wack. I tried doing many laps with messed up toe damage and you still can go reasonably fast.
Old Apr 4, 2014 | 11:19 AM
  #4215
User 52121's Avatar
User 52121
