2004 955 Cayenne fuel tank will not accept above 5/8 tank
I have an 04 955 Cayenne S. When I fill it up I cannot get above 5/8 tank without it shutting off. The gauge operates normally, indicating when fuel is low with the warning, so it appears to be functional in that respect. I have experienced issues like this in the past with other cars, so looking for ideas.
Flip the fill nozzle from the pump upside down when you're filling it up and see if that doesn't help?
Can't see how the sendwrs would cause the nozzle to shut off. Sounds like you have a tank venting issue. Does it cut off no matter how slowly you fill it?
The tank is full, the gauge reads 5/8 full. The gauge falls as it should as I drive, when I consume half a tank it drops down to 1/8. It is inaccurate, it should read full when it's full.
So there's 2 senders, how do they interact? If one fails, can it cause the gauge to read this way?
Someone indicated there's a high level and low level sender. If the low has a sunken float it could in theory read 5/8 when full if they function as this person assumes. Of course there's no documentation to support from this person, so it's just their speculation.
Unclear if the issue I faced is directly related to yours but when I had my original fuel pumps replaced (at 165k miles!) the hoses tangled the fuel level float and I was unable to fill up to 4/4 as well.
Perhaps it’s gotten tangled?
I am traveling this week and weekend, so I’ll have to wait to get into it.
