Wire runs for SoloDL in 997.2
Starting to think about how to run the power and CAN (SoloDL to SCHD) cable from a SoloDL mounted center windshield to the fuse box in the driver footwell and then back to the SCHD on the cage.
Looks like from the Solo, the wires can tuck along the gap between the top of dash trim and the windshield.
When we get to the front left corner, the question is which trim removal most easily permits getting the wires down to the fusebox. Seems like maybe the A pillar trim, but I'm not certain. What is recommended? How to remove?
Then, from the fusebox back to the cage mount I just have to get under the carpet piece covering the inside door sill. Might need to remove the hard plastic long trim piece on the top of that carpet that contains the frunk and engine bay release. Need advice on how to remove this piece. Seems like there are two screw caps of sorts on its inside edge.
Related thoughts welcome.
db
db
