AiM $100 IR Tire Temps! For Sale now!
Basic Site Sponsor
Basic Site Sponsor
Received 3,116 Likes
Matt - many thanks for posting this. In my quest to further develop my car, it would be very important for me to get the temps across the tires but there is a limit to what I can fit in the front wheel well. It's already pretty tight in there. Let me do some more research....
Sorry, Matt. Thanks for having my post removed.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
I looked at the Izzy sensors before but it just gets too expensive for my application at $300 a sensor. Maybe a single sensor at each wheel plus track temp would already get me most of what I would want to get started.
Rennlist Hoonigan
which cost no drachmas
Single sensors on the wheels will give you a lot of data and you can always expand it later if need be. If you want to see some data from this sort of setup, let me know and I can send you some to play with.
Matt - please send me what you have in terms of sample data. Sent you another PM.
I do have another dumb question.
Is the idea that you want the surface temperature of the tire the same across all 3 sensors??
So the right rear in this example would need some pressure adjusted or a suspension adjustment??
Rennlist Hoonigan
first of all this is am amazing thread. Thanks for posting this.
The plan is always even Temps, regardless of how you measure them. You also want to make sure the front to tear Temps arw in the tight operating range and don't show any chassis balance issues. You also want to make sure the Temps are in the best operating Temps for you tires.
On my car the suspension geometry of the rear tires in droop is terrible, so the Temps go really bad.
Rennlist Hoonigan
I thought I would give this thread a quick bump. For anyone that wants to really set up their car, has trouble getting help recording temps, or wants to really learn about tires, this is a great way.
Basic Site Sponsor
Basic Site Sponsor
Agree with Matt. I think a lot of people fight balance issues that information collected by these sensors could validate, and therefore guide setup to fix them.
Basic Site Sponsor
Basic Site Sponsor
Rennlist Hoonigan
I have made car and driver changes. No droop limiting - yet. The last time I did that on a car it didn't end so well...
The chassis part has been very interesting, with tire pressures, alignment, and shock changes. What has been equally, if not more interesting, is learning tire behavior. Different tires perform so different in what it takes to get them to the operating temp, how long it takes, what conditions make them work right, etc.
Same thing goes for IR rotor temps with the Texense sensors. I have changed brake compounds, ducts, and some other things all based on the rotor temps.
Did you try smaller tires? I wonder if the temps would come up better. Your car is a light car and may work better with less tire. I know you've done a lot of research. What temps would you want to see if you had the "perfect" setup?
Rennlist Hoonigan
For my tires, I find 170-180F mid corner to provide the most grip. This is highly dependent on track temp, air temp, and the asphalt at the track though. Once you have IR temp data, you can do an XY with temps and lat/long grip, GSum, or grip factor and it will easily show you the optimum temp range for that tire.
Basic Site Sponsor
Basic Site Sponsor
Interesting though, because your observed temps are below by some significant amount the target range for many slicks. Is that an R-comp thing?
Rennlist Hoonigan
Every tire has a specific range that is unique to it. I've seen different slicks vary quiet a bit as well. Working with some of the tire engineers on this sort of stuff has been very interesting.
