AIM Car data from a 964
Hey there - I have a SOLO DL + Smartycam HD. Love this setup. I'm swapping between my 997RS and 964. 997RS its plug and play to get car data.
964, how can I get some basics from the car? At a min would be RPM, throttle would be fantastic, I can use Gs to determine braking but 'real' data would be better. Maybe those 3 to start.
I'm not looking for race car level instrumentation, but some basics would add to the visibility of when I'm on gas, when I'm on brake, etc.
Any guidance on what I'd need? (and yes I know I'd need to swap configs on the devices when bringing between cars).
Basic Site Sponsor
Basic Site Sponsor
Received 3,270 Likes
G's, speed, track mapping and lap time.
That's it for the Solo DL.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Rennlist Hoonigan
which cost no drachmas
The Solo DL won't take any additional inputs, so you are out of luck with the 964. Looking at your build thread, if you want to add get some more data in that car, I would suggest an Evo4 with a G-Dash on a suction mount. That way you can hide the Evo4 under the dash, put in a brake pressure, throttle position, and steering sensor to have a great array of sensors, and then put the G-Dash up when you are at the track. This will be the least invasive install and still give you great data. I even make up a nice mount that goes with the G-Dash so you can put the GPS antenna with it so you don't have to permanently install that. It's a slick setup.
If you want to explore that setup, let me know and I can give you prices with a Rennlist discount.
The Evo 4 is great. I believe you can get an RPM feed and throttle position on a 964 pretty easily by just by tapping in to the coil and the TPS wiring. The brake pressure probably needs a separate pressure sensor installed near the master cylinder. The problem with preOBDII cars , no truly simple way to plug and play.
Basic Site Sponsor
Basic Site Sponsor
I have new EVO4/G-Dash combos pre-configured for your specific application in stock, have done several.
But just connecting your Solo DL to switched power and attaching the SmartyCam will give you plenty to work on right now. Heck, you could SEE the tach with the SmartyCam, if you placed it well.
Be glad to help whatever you decide to do.
