RS3 Custom Sensor file conversion? csr > snsr
Old 03-11-2015 | 11:51 PM
pmason's Avatar
pmason
Default RS3 Custom Sensor file conversion? csr > snsr
Finally getting my car put together enough to get the MXL2 installed. Building a spec miata. I picked up one of the Iron Canyon fuel level sensors and part of the install they provide 2 custom sensor files to be imported, "csr" is the file extension, but going into RS3 it looks to only accept "snsr" file extensions.
Anyone know of a file converter tool?
Old 03-12-2015 | 01:34 PM
jwasilko's Avatar
jwasilko
I don't think you can import sensors from rs2 into rs3.
I just lookedthe sensor config for all of my custom sensors (4 of them, ugh) in RS2 and recreated them in RS3.
Old 03-12-2015 | 02:33 PM
pmason's Avatar
pmason
Yes I pretty much came to the conclusion that I will have to create a custom sensor from scratch but shouldn't to hard. That was also the same response I received from Mark at ICM.
Note the files look to just be text files as I could open them and pretty much read the values, etc.
Old 03-12-2015 | 09:35 PM
Matt Romanowski's Avatar
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
As far as I know, you have to remake them, but it's really not hard. The RS3 sensor config also lets you create the configs in ohms (with the resistor value) as well as mV. It's not needed here, but it's a really nice little feature.
Quick Reply: RS3 Custom Sensor file conversion? csr > snsr
