Brake switch on 996 Cup Car
In the data files of my Cup car I would like to see when I actually start pushing the brakes. I know I could/can do this using a math channel on my deceleration g's but it would be nice to have something precise. I've heard about using an extra channel on my EVO4 logger that I could simply wire on the brake lights? So when the light goes on ( = you pressed the bitch pedal) it stores it in the logger (basically an on/off channel).
What kind of connectors/pieces would this require?
I was just wondering if I could use the power that goes to the brake light directly, or if I need extra stuff to make sure that the EVO doesn't receive more than 5V. Don't want to blow that thing up, it's quite expensive
This is what I found in a doc:
EVO4 acquires:
5 analog inputs, at a configurable frequency from 1 to 1000 Hz per channel. These signals can be: 0-5 Volt, 0-500 mV, 0-50mV, thermocouples K.
EVO4 acquires:
Rennlist Hoonigan
which cost no drachmas
I don't think you can put the 12v into the Evo4. You would have to do a relay with the relay switching the 5 volt signal on/off.
Basic Site Sponsor
Basic Site Sponsor
From: Durham, NC and Virginia International Raceway
I got rid of my post because Matt is correct, no 12V is allowed in CH1 through CH5, but you need to find out if the 996 brake switch is switch on=complete circuit to ground. Or you could do it through a relay, easy because you just complete the circuit to 5V vRef to signal in and then you're set.
There are many ways to do this, it is valuable and worth doing if you don't want to add a brake pressure sensor.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
This was driving me crazy, I couldn't remember if it was MoTeC or AiM that we did this with a million times. The answer was, we did it with both. I pulled up the dash configs we have in archive for Evo4 and MXL's.
For AiM, in a Spec E30, SPB, and a few other cars the way to do this is to use an analog channel. Use generic linear 0-5v @ 2Hz. Wire pin #3 (+VB) on any free analog channel to the positive on the brake light.
Go ahead and test it first. Trust but verify right? ;-). Take your multimeter and put it on negative at the brake light, then hit the brakes.
Hope this helps.
Hope this helps.
Ah, made mistake in what I said, should be hot side... (I corrected it above).
From AiM:
From AiM:
You would have run the switched side (hot when brake is engaged) of the light to one of the analog inputs. Even though the inputs are only rated to register a signal from 0-5V, they are capable of accepting up to 20Vs in without harming the system. From there, you simply create a custom sensor calibration in the software. Something like...
0mV = 0 value
5000mV = 1 value
Basically, an analog on/off state, which you can then review in the data.
0mV = 0 value
5000mV = 1 value
I found that you can quite easily go from 12 to 5 V by dismantling some random USB cigarette lighter car charger and using the electronics (opened one and it is pretty straightforward it seems).
And being the complete noob that I am (and by noob, I really mean NOOB), where should I start looking to find that wire? Anyone got some schematics to see how to access that wire? I opened the engine lid but didn't see much there. Maybe I need to remove the rear bumper? Or Can I access the correct wire somewhere in the front part of the car?
The problem is that I'm always scared of screwing things up, but if I never do anything myself I guess I'll never learn doing something myself ...
In theory it sounds simple:
- find brake wire +
- take an AiM cable and connect the input voltage pin to a wire to connect to the brake wire + (do I only need to connect 1 of the 4 wires? No negative that I need to connect to the chassis?)
- use some kind of positap connector to connect both
- route the AiM cable through the car
- program and test
In practice it always seems like mission impossible for me once I sit next to the car.
Well, maybe it's not a surprise, coming from someone who doesn't understand why you don't get electrocuted in your car while the negative part of the circuit is wired to the chassis
I m more at ease replacing brakes and cleaning wheels
So any suggestions, tutorials, links to help me out a bit?
- find brake wire +
- program and test
Don't worry about 12v vs 5v per my previous post.
Typically you can use a wire to either tail light or the 3rd light. Or sometimes there are wires coming off a switch at the top of the brake pedal. If I remember correctly, 1999 Boxster had such a switch. I can look at wiring diagram in Bentley book later.
The other thing is you will want a single wire soldered to a binder connector for the Evo unit. Alternatively you could take an extension and cut it up, but that's hacky. We used to sell a kit for this when I did this for business, perhaps one of the AiM dealers could make one for ya.
