I have installed an AiM solo 2 DL with a smartycam Dual last month. Its using the OBD port for information.
I was told by the installer that there isn't a can channel identified for the Brake Inputs yet? I am willing to have them use a can tap to get this info if its available.
While we can theoretically use the GPS/deceleration for info, I was hoping to have more direct measurements.
Does anyone know how I can get the brake information using my setup? Do i need a separate wire into the CAN bus?
For other systems, all that comes through directly wired to CAN, right side footwell.
__________________ -Peter Krause www.peterkrause.net www.gofasternow.com
I thought it could but they mentioned that for the 992 they don’t have the protocols yet for the brake inputs. I’ll ask them again to look into it
Actually, I just checked. While there has been an ECU Stream that has been up for some time listed 992 OBDII, there is now a new ECU Stream listed in RS3 called 992 GT3 OBDII that shows brake pressure available! Looks like this. Be sure to check 120 ohm termination. Use Accel position, also.
Thank you! That worked!!
My ECU stream was the 992 OBDii. when i switched it to the GT3 version brake pressure showed up. I double checked on the live signals and when i pressed the brake it indeed picked it up on the RS3 interface.
