Can anyone tell me how to access the vehicle can database in the setup config for vbox? My only options currently are racelogic module or user config. There is no drop down to select the vehicle can database. I am connecting it to a Motec CDL3 and have all the wiring done just can not seem to access the database. All the instructions say it should have been included with the software install?
Thank you Heath
You need VBOX Video, which is the app to set up the scene, or configuration file. These are the directions to the VBOx to tell it what it's connected to, what to show on the background of the screen, when to stop and start, etc, The scene, when it's done, can be saved to the root level of the SD card and inserted into the HD2 after it has been powered up and booted,
This is a two step process, You need to configure MoTeC in your Dash Manager to add the VCS Compounf Full Transmit or HD2 template to the signals sent out via the MoTeC CAN at the correct bus speed. Then, in your scene configuration in VBOX Video, you select from the top left corner the "CAN" setup page from the drop down menu, this has the connection settings on the bottom of the page and allows you to associate the channels of information to elements, or animated values or icons on the background of the video. The MoTeC is limited, but has all of the channels needed to do comprehensive driver analysis.
Glad to help you further. It's my business. Once done, it's set for life!
__________________ -Peter Krause www.peterkrause.net www.gofasternow.com
Peter thank you, I just got a response back from Racelogic. My problem was in the Vbox video software I was not able to access the “vehicle can database” it was only offering me the user config or racelogic options. They emailed me the file so I’ll be uploading it today. Then if I am still stuck I’ll let you know.
Here's a sample MoTeC scene from a Super Trofeo with a MoTeC C185
All of the channels that come through with the preloaded template. You can do more, but you would have to build your own template on both sides (MoTeC and VBOX)
Here's the guide from MoTeC and VBOX for their official link up and how to connect the systems to one another. MoTeC decided to end production of their own video solutions some time ago and forged a relationship with Racelogic to use the HD2 as their preferred video solution.
