Solo DL2 in a 986 boxster
#31
Water temp and Intake air temp may be the only worthwhile things you can get from ISO 9141/2. RPM and TPS are definitely too slow to be usable.
Used to be that if you select an ECU Stream to get some of the channels from that, you couldn't use the conventional square-wave RPM signal under Channels. But that seems to be fixed.
Sounds like you have a plan!
#32
Rennlist Hoonigan
which cost no drachmas
You have been able to run RPM and K-Line / CAN on the Solo 2 DL for a long time. I have not tried new hardware on the 986 with the ISO protocol. It worked, however slowly, on the SDL. The S2DL works slightly different on the k-line and I would want to test it before I committed that it worked the same.
saamyjoon (02-16-2021)
#33
Basic Site Sponsor
Basic Site Sponsor
Received 3,270 Likes
Considering it was close to a year before K-Line handling was supported in the latest Gen hardware (the S2DL), I don’t blame you for not testing it. I haven’t heard of that connection protocol working with the 986.1, on any logger.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#34
Update on how it worked out:
I wired the K-line in the 986 to an MXS. The goal was just to grab water temp from there (and a few other things if they were available). It does work, but the update frequency is so low that the dash will actually show a blank “tile” between updates, which happens maybe once every 10 seconds or so. So what was happening is the Aim would show water temp for 1-2 seconds, blank ~10 seconds, repeat. (Same for IAT.) So it’s possible to get data this way, but it’s not ideal given the Aim decides to not leave the last reading up. I didn’t look if there was a way to configure a timing interval before Aim showed a blank.
I had an Aim water sensor ready to go, and given how trivial it is, I installed it instead of trying to figure out how to configure the MXS to not show a blank. I installed the temp sensor in the coolant drain plug, which is conveniently M10x1.0 like the Aim sensor.
#35
Basic Site Sponsor
Basic Site Sponsor
Thanks for doing that test. The SPB, required to be within ‘97-‘99 model year, is just a trace too early for the simple communications that emerged as soon as 2002 in the 986-996 cars.
Another popular comp car, the NB (1.8 liter, 1999-2003) Miata has the same issue.
These cars are nearly twenty-five years old!
saamyjoon (02-22-2021)
#36
Rennlist Hoonigan
saamyjoon (02-23-2021)
#37
Basic Site Sponsor
Basic Site Sponsor
Data, in itself and by itself, is just a record of what went on.
When leveraged in many different ways, it’s a powerful tool.
Especially in a spec or very competitive class of racing.
#38
You made the correct choice IMHO. You could try changing the polling on the coolant to 1 Hz, but I don't think it would have changed things. Once you have a dash, addng the coolant sensor is easy enough and they are not too expensive. Spec Boxster is a class that IMHO data can make a significant difference in car and driver.
Just for posterity: you’re correct about the 1hz refresh rate. I tried that when I first installed it, and it doesn’t work. The above description of what happens is with it set to 1hz.
ProCoach (02-23-2021)
#39
Fair feedback for sure. I may just dump AIM altogether and move to a Vbox HD2. Any suggestions or concerns for that choice in our platform? Im assuming that we would tap into the CAN Kline with it...but when I look here
https://www.vboxmotorsport.co.uk/ind...uments#Porsche
I see no support for our car. Sweet.
FYI, I have several VBOX Lite's and Pro's for sale or rent and a used HD2 on the way for rental only. I also have OLED's and a Solo DL for rent or sale.
I'm not intentionally trying to start an enterprise, I've just upgraded 4 times since I started my latest project. But a 2 Camera VBOX Lite and Solo DL combo provide everything I need to easily improve my lap times and my car's setup.
