AIM MXG NTC Temperature Sensor Issues
We have an MXG installed in a Boxster S Race Car. We just did some transmission work and installed a bung for an NTC Temperature sensor (Bosch NTC M12 -40 to 130c temp sensor), however we are getting strange readings on the dash.
What we have done so far:
Any help or guidance would be appreciated.
- Created a custom sensor based on the resistance/temp table for the sensor
- Wired the sensor to a AIM 719 plug to Pin 1 (Analog Signal) and Pin 2 (GND)
- We have tested the sensor and based on the resistance in the table the temp is correct
- We tested the wiring and the resistance at the 719 plug end is the same as what is read directly at the sensor end.
- We have pluged it in to 2 different analog inputs on the 37pin AIM wiring harness with the same result.
- The dash is reading 165 Degrees C, way beyond the range of the sensor and equates to 0 Ohms.
Basic Site Sponsor
Basic Site Sponsor
From: Durham, NC and Virginia International Raceway
Your diagnostic train sounds good.
Primary harness to the MXG is in question for that channel.
Ping your dealer or AiM Sports in Roanoke or Lake Elsinore, California for additional support.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
ProCoach (02-28-2021)
Rennlist Hoonigan
which cost no drachmas
Have you tried a different sensor on the same channels that are not working with the temp sensor? If those work, then it's a wiring problem.
Pull up resistor between vref and sensor wire,.other sensor wire to ground, correct?
Am I supposed to also link Vref to Pin 1 via a resistor?
Rennlist Hoonigan
Yes, that is the pull up resistor. That converts the resistance to a voltage. The value you see on the custom sensor screen is what is used to calculate the voltage that results from the circuit.
It won't work until you add the pull up resistor.
