From: Durham, NC and Virginia International Raceway
Reach out to Robbie Yeoman at AiM in Lake Elsinore California. He's the US based CAN engineer and probably has, or can get from Italy, that info.
I spoke to him this week about these measures on other protocols, and they have to do with the manufacturer's ECU mapping for fuel and ignition, based on temps, pressures, MAP, throttle load and a number of other factors.
Meaning, they are not accurate OUTPUT numbers, but rather what the manufacturer expects to see, at that moment and based on the ECU map. That map is generated by all other measures (some referenced above) required to build it.
__________________ -Peter Krause www.peterkrause.net www.gofasternow.com
Rennlist Hoonigan which cost no drachmas Lifetime Rennlist Member
Rennlist Site Sponsor
You can also talk to Tyler. He and Robbie share a lot of the CAN tasks and knowledge. I have to double check the address, but ecu@aim-sportline.com.is the ECU CAN team and can probably give you a detailed description.
