AIM IAT and Logger Temperatures
Old 07-22-2018 | 08:31 AM
mlct's Avatar
mlct
Default AIM IAT and Logger Temperatures
What is the IAT temperature AIM reports and where is it measured?
I assume the Logger Temp is..uh...at the logger so it measures the inside of the car. Is that correct?
I should(!) but don't always make a record the outside air temperature and am logging for something in AIM to use.
Thanks,
Mark
Old 07-22-2018 | 10:59 AM
Matt Romanowski's Avatar
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
IAT is the air temp in the intake track. The logger temp (cold junction in the AiM dash) is a good approximations of the ambient temp. Exact location of the IAT is dependent on your car and it's influenced by engine bay temps. It's the air temp your engine uses for the ECU and engine management. It's also what all the cold air intakes and the like try to lower.
Old 07-22-2018 | 11:00 AM
Matt Romanowski
Rennlist Hoonigan
You can also use weatherunderground.com and look at the historic data. That will give you air temp throughout the day, humidity, wind, etc. It's a great tool for planning too as it will give your historic averages as well.
Old 07-22-2018 | 01:28 PM
mlct's Avatar
mlct
Thanks. After I posted I starting wondering if there was a weather site with history too. I am covered now.
Mark
Quick Reply: AIM IAT and Logger Temperatures
