AIM Smartycam sync with MXL2 data?
Old Dec 22, 2017 | 11:05 AM
pmiranda's Avatar
pmiranda
Default AIM Smartycam sync with MXL2 data?
I want to be able to quickly flip through laps, see what I did in a given corner in video (where I positioned the car, was I in traffic, etc.), and look at the data in RSA to see what worked better from lap to lap.
I have been able to bring in video from a different (dumb) camera into RSA and get it synced with data for a single lap but it is pretty time consuming.
If I got a smartycam, would the data and video in RSA automatically come up in sync for every lap I look at, or do you still have to manually line it up?
Old Dec 22, 2017 | 11:16 AM
Matt Romanowski's Avatar
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
The SCHD will automatically write the data on the video and the laptime in the video will match the time on the data (if you look at the data on a time basis), but there is no way to click a point on a graph in RS2A and put the video to that point. That is being done in Race Studio 3 Analysis, but it's still in development.
The beauty of the SCHD is that the camera turns on, starts recording, stops recording, turns off, and puts all the data on the video automatically. It's a one time configuration and then it just works. Take the memory card out and watch the video with data.
Old Dec 22, 2017 | 11:24 AM
pmiranda's Avatar
pmiranda
OK, thanks. I guess I'll wait for my current camera to die before I bother upgrading.
Old Dec 22, 2017 | 12:17 PM
ProCoach's Avatar
ProCoach
Basic Site Sponsor
From: Durham, NC and Virginia International Raceway
To add a little to Matt's good points, any HD version of the SmartyCam (Rev1, Rev2 and Rev2.1) is capable of recording information, or metadata, to the video file that will eventually be used to do what you want to do.
The software is the limiting factor now, as long as you're using any hardware that requires RS3 to configure it. I think this is the most anticipated feature that AiM Sportline could release...
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Old Dec 26, 2017 | 11:27 PM
IPSA's Avatar
IPSA
If I am running RS2 but my hardware will run RS3 should I convert going forward and what are the ups and downs of doing so ?
Cheers
Old Dec 27, 2017 | 08:55 AM
ProCoach's Avatar
ProCoach
Basic Site Sponsor
Cheers
IPSA, what hardware do you have?
RS2 is included in RS3 for those older file format devices that need it for configuration and download. Solo/Solo DL/MXL Pista/EVO4/EVO3 and the older MyChron line.
RS3 is for the “new” file format devices that need it for configuration and download. Solo 2/Solo 2 DL/SCHD/MXL2/MXG/MXS/MXP/EVO4S/EVO5 and the newer MyChron 5.
You have no choice. The hardware determines what configuration and downloading tool you use. With the Solo 2 and EVO4S introduction, the transition is complete, from a hardware point of view.
RSA, Race Studio Analysis, the data READING program, is included in both RS2 and RS3 and opens both file formats from old and new hardware. It will be eventually replaced by “RSA3.” A software program that will allow integration of video with the data on the screen. That feature will be limited to data and video generated by hardware that requires RS3 to configure and download.
That’s also some ways off. HTH.
Old Dec 27, 2017 | 02:33 PM
IPSA's Avatar
IPSA
Running Solo DL w SCHD Rev 2.1
Is the next best step the new SOLO 2 or the MXm I believe?
So if I understand you I will be able to review data from RS2 and RS3 at the same time at some point? I.e. compare my old RS 2 laps with new RS 3 laps ?
Also when is the side by side video option available ?
Cheers
Old Dec 27, 2017 | 02:43 PM
Matt Romanowski
Rennlist Hoonigan
Cheers
To do the eventual integrated data/video review, you would need a Solo 2 or MXm. Which is better depends on your needs. If the Solo DL you have does everything you want, no need to upgrade to the MXm.
AiM has always had and will continue to have full compatibility in all of it's data files. You will always be able to compare your data whether it's from your Solo DL, a Solo 2, any of the dash loggers, or even the kart systems. What software you need to download the data will not change that.
Video and data review (click a data point and the video goes there) is still a bit away. If you want to compare to SCHD videos (or any 2 videos) side by side, I suggest www.comparemylaps.com. It's terrific and works with any video files.
Old Dec 27, 2017 | 07:51 PM
IPSA's Avatar
IPSA
Matt and Peter
Thx for the info and service to our crazed band of brothers...
Will stay tuned
Cheers
