Recommended rubber protectant
I understand the rubber seals and trim used on the exterior of old Porsches, such as the rubber around windshields, were not the best and therefore didn't hold up very well unless taken car of.
Any recommendations?
Location: London,UK / Florida US State- Dazed & Confused
The seals on automobile are no longer made from natural rubber. Auto manufacturers use a specialized synthetic material called EPDM, (ethylene propylene diene monomer). Natural rubber or blends that contain rubber cannot endure the direct exposure to ultra violet radiation (UV) and oxidation.
Some vehicle manufacturers such as General Motors also recommend a light application of silicone dielectric grease to weather-stripping to reduce noise. EPDM has extremely poor resistance to solvents and oils.
Do not use a cleaner or any chemical product that contains oils or Dimethalsilicone (DMS) usually a clear greasy liquid, which leaves a never-dry gloss film, as most contain petroleum distillate solvents that are that are incompatible with EPDM.
Exterior - For dull or faded seals or window mouldings- remove imbedded white stains in vinyl and rubber mouldings; first wipe the mouldings with a multi-purpose cleaner. P21S® Total Auto Wash or 1z Plastik Reiniger (Deep Cleaner) both products are excellent for this task. This removes any wax / polish / silicone debris and dissolves surface stains.
Light scratches – Use Maguire’s ScratchX and a terry cloth towel
Protection - with 1z einszett Vinyl Rubber Care & Potectant "Tiefenpfleger” provides a temperature-resistant seal and a low-shine matte finish Dust-resistant and retards the fading effects of UV rays to keep exterior ‘rubber’ and vinyl looking like new. Apply (every three months) with a micro fibre towel or applicator pad and give the trim a quick once over.
Interior - The soft seals around doors, windows, sunroofs, hood and trunk are constantly being flexed and compressed all the while being subjected to a hostile environment. The inside edge of this gasket is usually felt lined and can/will pick up contaminations (oil / grease) as the window is operated. Be sure to clean the inner gasket edge thoroughly at the same time you're cleaning the guides.
Iz einszett Rubber Care Gummi Pflege Stift - (which translates to rubber maintenance, doesn’t simply buff rubber to look new; it provides real, deep down protection, prolonging the useful life of the seal by restoring the original moisture and resist tearing and sticking
Applications - quick and easy to apply – simply run the sponge applicator along the rubber trim and you're finished.
The P21S mentioned is a superior cleaner. I do all the tough areas with it, engine bay, wheel wells etc. Spray it on, wait five minutes and hose or soft brush the surface clean. Paint and plastic friendly.
Dress the "rubber" with Aerospace 303. Great product that will not seal the surface. It also adds UV protection and a nice satin finish when it dries.
Pretty affordable too.
+1 on 303. Readily available I believe and it works. Good on tires, too.
If the trim is really bad, I'd use Griot's Garage Rubber Cleaner then their Rubber Prep. Then 303 Aerospace.
I forgot I had some of the Einzett Gummi Pfledge stuff. VERY good product, too.
