Dealing with Dust: Recommendations on Wax/Detail Sprays
Guys, Our garage is located near my wife's garden. As a result there is a fair amount of dust in the air. I have a black car.
Just wondering if there are particular types of wax and detailer sprays that have a tendency to attract or repel dust. Looking for products that may make it easier ito maintain in this respect. Obviously the less wiping on a black car the better to reduce scratching.
Any input much appreciated!
Any wax or sealant I've ever used has always increased the static charge on the surface of the paint which makes total sense when you think about it. Static is generated by rubbing a surface so when you wipe the wax/sealant from the surface you are generating a charge.
I really don't know any solution to this although if someone has successfully tried and can show me that a product exists to eliminate static I would definitely buy it (as long as it doesn't harm the paint).
Location: London,UK / Florida US State- Dazed & Confused
One of the first rules of paint care (especially noticeable with dark colours); the less you touch the paint surface; the less you’ll scratch it. Washing the car is the most efficient way of removing surface soil, dust, etc.
Quick Detailer (QD) - a typical quick detailer spray is formulated with 80 - 90 % Water, 0.5-1.5% Carnauba wax, 0.1 – 5% Silicone or Mineral oil, so they don’ have the inherent solvent content problems like spray waxes.
If you don’t have time for a two-bucket wash, then use a 1:20 Optimum (OPT) No Rinse Wash™ & Shine New Formula (ONR) / distilled water solution in a fine mist spray bottle.
The surfactants it contains encapsulate and trap dry surface dust, pollen or light dirt particles making them virtually non-abrasive and it can be used without causing scratches. Apply with a long nap micro fibre towel using very little surface pressure, dusting with long strokes in one direction only
Dust build-up-with low humidity conditions and friction on the paint surface will cause static electricity (this is exacerbated by the use of polyester (nylon) Micro fibre) resulting in dust attraction to the paint surface.
Reduced dust attraction can be realised by using Finish Kare #425 - Ultra Slick Polywipe contains polymer for lubricity, anti-corrosive agents, UV inhibitors and patented anti-static agents that gently remove fingerprints, smudges, and other light contaminates and reduced dust attraction.
Heavy Dust
To remove heavy dust use Optimum (OPT) No Rinse Wash™ & Shine New Formula (ONR) a quick ‘wash’; formulated with surfactants to keep dirt in suspension, avoiding surface contact, it also provides surface lubrication, thereby avoiding surface marring. Alternatively use Optimum Instant Detailer - this formulation penetrates and encapsulates light dust (pollen) dirt, and grime, allowing for their removal without scratching or dulling the surface. As soon as is practical, thoroughly rinse the vehicle with a hose and clean water to ensure all the pollen is removed.
Light Surface Dust
To remove light, dry surface dust without causing scratches apply very little surface pressure, dusting with long strokes in one direction only, use a product that contains a surfactant; this will lessen surface scratching as they ‘lift’ dust etc into the media used avoiding surface friction (use a solution of Optimum™ no-rinse (ONR) diluted 1:20 / distilled water in a fine mist spray bottle) or Optimum ™ Instant Detailer.
Do not use on a hot paint surface (soon after driving) as this will cause streaking?
Use a long nap micro fibre towel to ensure the dust lifted from the paint surface will remain in the nap and not on the towel surface thereby causing surface marring. Shake the towel occasionally to ensure any particles picked up will drop out rather than come to the surface while you’re using it.
It important to use this methodology only for the removal of dry surface dust, don’t use if surface has condensation or dew, or if the vehicle has oily road film, road tar, damp pollen or dust, etc in these instances the vehicle surface should be subjected to a conventional or Optimum (OPT) No Rinse Wash™ & Shine New Formula (ONR) car washing process
{Knowledge Management} - Treating experience as a shared asset. If this article was informative and you learned something new, or have any questions feel free to comment. We would love if you shared this article with your friends on Facebook and Twitter or linked to it from your website or blog- Thanks
Also see my Blog for constantly updated detailing info http://togwt1980.blogspot.com/atom.xml
Heavy Dust
Light Surface Dust
I am surprise nobody mentioned California duster. I don't apply pressure on it. Just drag from top to bottom. I haven't found a quick detail spray tht is a clear winner, I usually use a reputable brand and clean microfiber towels, lots of it. Again, I don't rub it in or wipe with force. If the paint was prep'd well, the towel will feel like it is sliding itself.
In my best Jeremy Clarkson voice......Some say that California Dusters can cause scratching, but I havn't found that to be the case.
Now that I own a black car I will gain more experience with what products work well and I'm sure I will be posting my feedback here.
I use primarily Meguiar's sealants/waxes, so I use their Ultimate Quick Detailer spray. Great results. It may not be a valid rationale, but I tend to use products from the same manufacturer, just for compatibility. Meguiars with Meguiars as mentioned, Griot's Speed Shine as a detail spray if I've used one of their waxes, etc.
Using products from a single mfg line is a safe and valid rationale; however most chemicals used in car care products are pretty basic and are usually compatible with each other.
Having said that, it’s great marketing strategy to convince the buyer of synergistic compatibility, by stating that that to obtain the best results you should stay within one company's line of products throughout the entire process (i.e. paint cleaner, polish, wax or sealant). Further stating that the reason for this is that the chemists that develop these products make sure they are compatible throughout the entire process. Each step building upon the results achieved by the previous product and process
This is marketing fiction more than scientific fact
