non Porsche daily driver wax recommendation
Lewis it's always good to get feedback. Collinite Insulator and most synthetics for that matter really lack in the depth and gloss IMHO. THey're really only good at maintaining an already well prepped surface.
Super Moderator
Needs More Cowbell
Needs More Cowbell
I sort of knew that going in, but I just wanted to see since I hadn't used anything like this before.
My son's car really should have had a full surface prep (at least clay bar), but that will probably happen in the fall.
If the 845 and 850 work as advertised, I'll do it again (heated garage) right before winter.
Next up is my new Golf TDI...and I'm not looking forward to installing the Xpel headlight film that arrived on Friday....never had luck installing that stuff
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Super Moderator
Needs More Cowbell
Needs More Cowbell
Will do.
OT, but the heated garage was a very simple and economical installation.
I purchased a Modine ceiling mount gas space heater from my local plumbing supply house (scratch and dent, so price was discounted), my local heating company gives the propane tank and connection for free (since I buy my propane from them), and the mechanical install was a simple pair of threaded rods connected to a 2x4 between 2 ceiling joists.
The whole thing was about $700 total and can run a full winter at 45deg on about 100 gallon LP.
45deg is perfect for melting snow and ice, but if I want to wash/wax in winter, just kick it up to 70deg and in about 30 minutes it is t-shirt weather indoors.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Did a second car this morning, just to see how 845 works in high humidity environments (since the dew point at 7AM was about 75deg and it was already 82)....indoor sauna in the garage.
No problems as far as I can tell (being a clueless detailing hack).
Went on and came off as easily as it did a few days ago when it was much drier.
It also does not seem to stain 'black trim', as I did get a little bit on the rear black plastic fascia but wiped it off immediately and no sign of staining.
It doesn't really make very much 'white wax dust', since it goes on very very thin.
So far so good, now we just have to wait and see how long it holds up.
Basic Sponsor
Cell: 210-315-8300
XPEL Inc.
Support@XPEL.com Phone: (210) 678-3700
XPEL.com "Like" us on Facebook Follow us on Instagram
![](https://rennlist.com/forums/signaturepics/sigpic82355_4.gif)
XPEL Inc.
Super Moderator
Needs More Cowbell
Needs More Cowbell
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Needless to say, it didn't go very well. I watched the video, I had my heat gun, I had my alcohol/water spray bottle....
I'm sure at some point I'll have to remove them and have a professional install new ones, unless I get used to bubbles and trapped fluid/white spots under the film.
And to think I don't even drink.
Thank you for the offer though, it is appreciated.
Sorry to hear that the install didn't go well. Can't comment on the bubbles, as my install was bubble-free. Didn't use a heat gun, as on the install day, it was blazing hot, keeping the film soft. As for the white spots, though, expect them to disappear in a few days. I'm sure XPEL will chime in, but I thought I'd share a few comments in the meantime.
I'm surprised at the lack of suggestions for sythetic wax. It lasts much longer but doesn't have that last ounce of depth to it. Great option for a DD like the Golf. Less expensive and will probably fit your needs better. Consider something like Prima Epic.
Super Moderator
Needs More Cowbell
Needs More Cowbell
And after a first rain test (torrential/flooding rain) while out driving, it beads water exceptionally well....once parked and left to dry, there was virtually no dirt on the car.
So far 845 is cheap and easy to use....if I get 5 months out of it it will have been worth it.
Wait, I just visited the Collinite website and saw this:
"They have discovered that Collinite Marque d'Elegance gives their valuable automotive investments a blinding, lasting shine because its formulated from the highest-ever concentration of pure Carnauba waxes."
Not sure which Collinite product you were referring to, but MdE is certainly not synthetic.
