MoeClip: Engine Detailing - Rolls Royce Phantom
Premium Sponsor
Here's my first attempt at what will soon be a series of how-to video tutorials.
This edition is a 4 minute tutorial on proper engine cleaning. Keep in mind, each vehicle is different and will require its own unique procedure. The techniques demonstrated in this video will apply to most newer vehicles. Main aspect to remember is to properly cover any open intake manifolds, open electrical connection, or any other water-sensitive areas. Aluminum foil works best to cover areas previously mentioned.
Hope this video helps you guys out...let me know what you think.
http://www.youtube.com/watch?v=JIanUYmyBgQ
Specializing in Porsche/Ferrari since 1995
Why choose GP...WATCH OUR DOCUMENTARY
Follow Moe HERE
GP Fastrak - Ceramic/PPF/Tint in one simple bundle - Click Here for more info
![](https://rennlist.com/forums/signaturepics/sigpic41851_5.gif)
Follow Moe HERE
Location: London,UK / Florida US State- Dazed & Confused
Protection of Electrical Components
The most important electrical components are sealed ‘water resistant’, that is to say against low pressure, water splashing encountered in the course of daily driving conditions. As long as you avoid directing a strong stream of water (or a pressure washer at close range) directly into these components, you will be fine.
You need to cover various parts prior to using any cleaning products, sprays (water deterrent, formula 40(WD-40)) or water.
• Alternator
• Alarm Housing
• Intercooler
• Battery terminals (if not covered already)
• Induction kit cone (if you have one)
• Coil packs
• Electronic control units (ECU)
• On-Board Diagnostics (OBD) port
• Air intake systems (exposed air filters) can be covered with plastic wrap and a rubber band
Notes:
1. This is not an exhaustive list, nor is it marquee specific, if in doubt use a water repellent (WD-40) and exercise common sense
2. Tin foil is a better alternative to using cling-film for the alternator, alarm housing etc as it is easier to mould and has greater protection properties. I suggest you use a plastic bag for the induction kit and just wrap it tight over the end to stop any water ingress.
3. For the intercooler the best way to cover is to get a flat sheet of cardboard and just cut it to size so it fits and covers the fins. Cardboard will normally protect the fins for the duration of the washing. It will get soaked so discard after the wash.
• Alternator
• Alarm Housing
• Intercooler
• Coil packs
Notes:
Premium Sponsor
Premium Sponsor
