Leather Touch Up, Great Solution
Old 07-06-2009, 12:59 AM
Marine Blue
Marine Blue's Avatar
Default Leather Touch Up, Great Solution
For years I've been searching for leather touch up paint which would eliminate the scratches and scuffs due to time/mileage. Here is a brief description of what I did to restore the leather.
Initial cleaning was with Leatherique Rejuventor/Prestine Clean and more recently with Leathermasters Strong cleaner.
I sent an email to Paul Champagne (THANK YOU PAUL!) asking for advice on how to redye/repaint leather in areas where the color has worn. He suggested Leather Magic's colorant products and mentioned that he had great results with their products.
About two weeks ago I finally ordered the product and gave it a try today. I didn't do any additional preperaton although it is suggested if your have a larger area to repair.
I applied it with a very fine tipped artist brush to help control application. The paint wasn't a perfect match which I suspect is due to age/sun of the 20 year old leather.
As I applied the paint I immediately used my finger tip to help blend it into the surroundings. Doing this made it nearly impossible to see where the leather was repainted. My finger helped spread the paint into the worn unpainted areas, the painted areas did not accept the paint so it made the application easy. Some areas reaquired two to three coats to fully cover the wear.
Here are a few pictures of the before and after. Note that the first pictures of the seat bolster when I bought the car and the second is what it looked like after cleaning. The rest are self explanatory. Feel free to ask questions.
Old 07-06-2009, 01:25 AM
IcemanG17
IcemanG17's Avatar
Afshin
That turned out VERY good!!
Old 07-06-2009, 02:15 AM
borland
borland's Avatar
Looks good. You might want to add another layer, but be careful you don't apply to much and mask the natural grain of the leather.
A little late, but to improve adhesion of the dye, you can use a tooth brush and leather cleaner to remove the grease from the leather before using the dye. Just need to make sure you let it completely dry before applying the dye otherwise the dye may have a problem adhering to the old leather and also wear much faster.
Color matching in different kinds of lighting can be difficult, although some colors are easy to match.
Your interior color looks to be 'Silk Grey' which Porsche only offered in 89' and 90'. You might also have 'linen grey' which they also offered that year. Did you order by color description or did you have to send a sample?
Got a link to the company web site? Prices?
Old 07-06-2009, 02:31 AM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,712 Likes on 1,314 Posts
Looks great !
What color code is your interior, Afshin? My GTS has a tri-color interior, with black dash/console, midnight blue carpets, and light gray seats. Here are the codes from the build sheet:
Interior Trim: MT
Interior Trim: Lthtt/Lthr Seat-Lt Grey/Black
Interior Equipment Code: KL Leatherette
Seat Combination Number: AQL
Seat Cushion Material: LED Leather
Seat Side Support Material: LE Leather
Seat Back Material: LE Leather
Carpet Color Code: 6YR
Sorry, totally washed out seats in the shot that shows all three colors:
Borland- where'd you get the MY availability of 'Silk Grey'? I'd be interested to know how that compares to Linen, vs. Light Grey.
Also, where'd you get the product, direct from Leather Magic, or a dealer? Half the webpages at Leather Magic's website are 'Page Not Found'
At least here's their Porsche color chart: Here's http://www.leathermagicpro.com/Pages...ecolrchart.htm
Old 07-06-2009, 06:44 AM
TOGWT
TOGWT's Avatar
Location: London,UK / Florida US State- Dazed & Confused
Leather or Viynl repair / re-colouring - http://www.magicmender.com/
Old 07-06-2009, 11:35 AM
Marine Blue
In a few of the spots I needed 3 coats to get proper color match, the brake handle for exampled needed this.
I did clean the leather with Leathermasters strong and a leather brush and I would strongly recommend this to anyone before they recolor. With the leather completely clean the colorant stuck to the unpainted areas like crazy glue. When I was sliding my finger over the cracks to remove the excess I did it almost immediately after applying the colorant and noted that it stayed in all the right place. I also dried quickly and it is perfectly pliable, really impressed at how easy it was.
Leathermagic has a Porsche specific color chart so it makes it easy to find the common colors. They also offer match to sample if you have a custom color. The only drawback to this paint is that it doesn't have the same satin look as the factory, if you look closely (a few inches away) you will see that it is slightly duller.
I spent 15 minutes on the phone trying to explain what I was trying to do and the guy was pushing me to buy the entire kit. Since I had no intention to spray the paint and I only needed to cover very small areas I asked for just the colorant which cost $25.00 plus shipping. The technique I used wasn't explained anywhere, I kind of figured it out after adding too much colorant to an area and I quickly used my finger to wipe off the excess. I realized at that time that it worked perfectly to blend and remove excess. I have a ton left over so I can touch up again in the future. Heres the link to what I bought: http://www.leathermagic.com/Pages/clrcoats_Dyes.htm
Originally Posted by Rob Edwards
Looks great !
Interior Trim: MT
Rob I posted the link above for the recolor. If you're covering larger areas you may want to opt for the kit. My interior is Linen and Navy but I haven't yet figured out what color navy it is. The color code on the window sticker says QD for the interior code, not sure where to look fo find what it is. Are you going to touch up the GTS or GT?
Old 07-06-2009, 02:17 PM
S4ordie
Not the sharpest tool in the shed
S4ordie's Avatar
Looks fantastic! Great job.
Your seat release levers look like htey are covered in leather. Is this true? I don't think I've seen any other release levers in any color other than black unless they have been painted or covered after the fact.
Old 07-06-2009, 05:44 PM
Marine Blue
Good Catch. Yeah the Seat Release levers are covered in leather as are a bunch of other things like the seat belt releases, hand brake surround, roof, rear hatch etc etc etc. Its good and bad, leather shrinks and I'm fighting to prevent it.
Old 08-02-2009, 12:36 PM
heinrich
928 Collector
heinrich's Avatar
Very rare to see full leather ... it was an X50 option or something, I'm sure you've seen the brochure pics posted on RL before Afshin. Tres Cool!!!
Old 01-20-2010, 08:42 PM
JWise
JWise's Avatar
Hi Afshin,
I just found some sport seats for my GT. The passenger side is like new, as is the driver's side with the exception of some bolster wear (see attached). I will follow your (and Paul Champagne's) advice in coloring, unless you think I should use a different method. Your opinion please, and thank you.
If any other experts would like to chime in, I would appreciate your input and advice as well. Thanks!
Old 01-20-2010, 10:09 PM
Marine Blue
Jarrod, very nice find with those sports seats.
This technique will work perfectly for the wear on those seats. The only time I would be hesitant to use something like this is if the leather was damaged (torn) or if it had really deep scratches. You would need to fill these areas first to get decent results. Minor scuffs will redye very nicely and blend perfectly with the surroundings.
Please post some before and after pics!
Old 01-20-2010, 10:11 PM
Marine Blue
Jarrod, don't skip the cleaning steps. Cleaning will help prepare the untreated leather for the dye.
Old 01-20-2010, 10:30 PM
JWise
JWise's Avatar
That's what I was hoping to hear. Clean, redye, post pics, done.
I'll go look at your thread over on RW for pointers as well. Thanks Afshin!
Old 01-21-2010, 12:43 AM
GlisteningTech
GlisteningTech's Avatar
Truly Proper Detailing is all about the little stuff. Every little thing. For those of us who are truly and wholly OCD, it is soothing to take care of the little stuff like that.
Good job on the repair, I know how hard it is to make it look as if nothing ever happened rather than something that was damaged and repaired.
Awesome to see that level of dedication and attention to detail.
Old 02-08-2010, 07:26 AM
pushtiulk
pushtiulk's Avatar
Great job with that touch up paint.
@JWise: You can contact leatherique and send them the pictures. They have good leather products (inclusive dye) and they will advice what should you do to re-dye your seat.
Quick Reply: Leather Touch Up, Great Solution
