Parked under a tree today
Guys
Posted this on the 993 thread - all the guys tell me to ask the guys here for advice.
Boys
I parked under a tree today while I was at the gym. When I got back to the car - it looked like someone had throw water bombs on the car. I just washed the car and I can't get the marks out of the paint work. The tree sap from that tree just won't come off. Can anyone suggest a product that will get the stuff off or suggestions on what to try ? I'm about to try to polish it out.
Regards
Boys
Regards
For sap, typically what I'll do is soak a corner of a microfiber towel in isopropyl alcohol and allow it to sit on the sap. After 30 seconds to a minute, try to pick the top of the sap off of the paint and hopefully the alcohol helped loosen it from the surface. You want to avoid scraping the sap off from the base of the sap mark which can add scratches or other imperfections to your paint. Another option is to use something like Stoner Tarminator to help break up and dissolve the sap. After the sap is removed, you can clay the surface to ensure there is no sap remaining on the paint. If the sap etched into the paint, then you'll want to polish out the marks to fully restore the paints finish.
Hope this helps, good luck removing the marks.
Cheers,
George
Cheers,
George
I've typically just soaked a section with quick detailer and used elbow grease with a Microfiber to remove the sap. It is tedious and takes forever but it won't harm the paint.
Location: London,UK / Florida US State- Dazed & Confused
Appears like a dark brown/ red coloured raised surface mark, some of the most common resinous tree sap types are: White Pine, Walnut (also secretes an oily residue) Maple, Oak, Popular, and Blue Spruce, none of which are water soluble, the acidic content of the sap will etch the paint surface; causing a concave surface.
A lot depends upon the type of sap, which is actually an acidic resin emitted from the tree, the resin deposits can be removed by- Isopropyl alcohol (IPA), a safe solvent (Stoner’s Tarminator®) or turpentine, which is made from tree resins, in severe cases it can be used to break down the resin in tree sap, use as a last resort only and use sparingly and do not rub hard and give it some time to work and then use detailer’s clay.
For more information see article “Environmental Pollutants” in the Detailing School section of Detailing Bliss forum...
