Recommended Product For Cleaning Carpets
I just purchashed a 94' 964 Cab, Black with Classic Gray Interior and Light Gray Carpet. It looks like the carpet has never been cleaned, although it is in good condition. I need a recommendation for the best product to tackle this job.
TIA
JF
TIA
JF
Start with a really good vacuum to remove as much dirt as possible.
Then use a diluted Woolite sprayed on to the soiled area. Follow with a damp rag to remove any remaining residue.
Griots also has a nice interior cleaner that works well and isn't too strong.
Avoid too much water and also dry everything as much as possible otherwise you'll end up damaging the silverknit.
Folex is a great cleaner and can be bought at Home Depot, WallyMart and Lowes.
As Marine stated, the key is a very thorough vacuum. The majority of dirt in carpets is plain ol dirt.
So vacuum, spray with Folex, allow it to dwell a few minutes, agitate with a carpet brush and then blot dry.
For your mats you can use the above method but since they are mats you can spray them down with your garden hose or a pressure washer, vacuum the water out (using a wet/dry vac) and then sit them out in the sun to dry.
Anthony
Anthony
My detailer uses a steam extractor much like the carpet outfits use in your home. Never asked what precleaner he uses but I know he's a big fan of 303 products.
The carpets come out looking brand new and the method is very easy on the pile and nap.
