Need a rotory buffer recommendation
Old Apr 4, 2008 | 12:37 PM
2ndof2's Avatar
2ndof2
Default Need a rotory buffer recommendation
Probably has been discussed before here....could someone please point me to an inexpensive rotory buffer (or thread discussing one) for detailing my car?
I would prefer an orbital since I'm a novice. This buffer would only get use about once or twice a year so it doesn't need to be an industrial strength one hewn from granite, just something thats lightweight, easy to operate, and most forgiving in terms of causing swirl marks (my car is black).
Thanks!
Old Apr 4, 2008 | 02:16 PM
gmblack3's Avatar
gmblack3
Porter cable 7424 should work out great for you. A rotary is different from an orbital. The 7424 is an orbital and what you want as a beginner to paint polishing.
Phil has this great buy going on.
Old Apr 4, 2008 | 03:21 PM
Darryl92Cab's Avatar
Darryl92Cab
I second that...the 7424 is very easy to use. You can achive great results, but it may take a little longer than a more agressive unit. I started with the 7424 and still use it as my "utility" buffer to this day. Have fun!
- Darryl
Old Apr 4, 2008 | 04:16 PM
2ndof2's Avatar
2ndof2
Thanks guys!
Old Apr 5, 2008 | 01:11 AM
detailersdomain's Avatar
detailersdomain
I would get the flex 3401 if you want something good ...
watch this video.
you have all the benefits of the pc being safe but much faster correction and more powerful machine.
http://www.detailersdomain.com/index...on=Custom&ID=3
Philip Yiu
Detailer's Domain
e-mail: phil@detailersdomain.com
website: www.detailersdomain.com
tel: 201-233-0003
Promo code is rennlist for 10% off anything on the site
Current Sales and Updates
Old Apr 5, 2008 | 06:56 PM
IcemanG17's Avatar
IcemanG17
an orbital is the best choice for newbies......the PC is very good but the flex or cyclo is better
Old Apr 9, 2008 | 11:32 AM
points's Avatar
points
I went to the auto geek show last week and tried most of the models available on hoods they had at various booths. I decided on the Makita because its both a rotary and orbital. Also light and easy to control. Went with the edge pads with the easy on and off part they sell.
Old Apr 9, 2008 | 12:53 PM
Jaak Lepson's Avatar
Jaak Lepson
Rest In Peace Jaak
Cable Guy
Or the PC 7336 ...
Old Apr 12, 2008 | 05:48 PM
MLindgren's Avatar
MLindgren
Are there any pneumatic random orbital tools that would be recommended for polishing. I have a UDM and hate the vibration and sound from the electric motor.
Old May 11, 2008 | 02:29 AM
JohanvdWalt's Avatar
JohanvdWalt
Another newbie here
I bought an orbital sometime ago, when pushed firmly against the paint surface it stop rotating and just vibrate, unfortunately all the brands that are well known to you guys are not available in this part of the world so I need to know what rpm and wattage to look for. Previously I always used a pad that connected to my electric drill which worked fine but I'm sure the right machine will give better result with less effort.
Old May 11, 2008 | 10:11 AM
Marine Blue's Avatar
Marine Blue
Johan,
Keep in mind that typically random orbitals do not work on the basis of rotating the pad, it's the oscillation that is created that does the work. This oscillation prevents heat buildup and is gentle on paint. It also prevents swirling from occuring when using polishes.
Judging by the pictures you posted earlier, you may need a rotary to get the job done and I would also strongly recommend having the paint measured first to insure you have enough to work with. Not sure if any of the Rennlist sponsors can ship to S. Africa at a reasonable cost, maybe they can chime in.
Old May 11, 2008 | 12:15 PM
JohanvdWalt
I'll try to find someone who can measure my paint, what if there's not enough left?
Will I simply go through to the under coat and it will be unsightly or will it be impossible to get it looking good simply because its too thin?
If the first then I'm not really worried about it because I will simply have the relevant panel resprayed, I will not be happy with it anyway while its not perfect.
Old May 12, 2008 | 03:04 PM
SBDinATL's Avatar
SBDinATL
Griot's sells pneumatic, but I don't know how good they are.
Old May 14, 2008 | 07:45 AM
TOGWT's Avatar
TOGWT
From: London,UK / Florida US State- Dazed & Confused
Alternative Rotary polishers –
Makita 9227, a favourite with many detailers’
Hitachi SP18VA is also popular, the 5 year warranty and slightly lighter weight
Metabo PE12-175 (German built) is also popular due to the light weight and great build quality.
Flex 3403 rotary is relatively new, it is also light weight
Dewalt 849 which is/was a popular rotary (heavier than most of the others)
