Feeler Group Buy on the CR Spotless system
need 10 to get a very very aggressive price.
Let me know.
Phil
Let me know.
Phil
Philip Yiu
Detailer's Domain
e-mail: phil@detailersdomain.com
website: www.detailersdomain.com
tel: 201-233-0003
Promo code is rennlist for 10% off anything on the site
Current Sales and Updates
Philip Yiu
Detailer's Domain
tel: 201-233-0003
Most of you know what this machine does.
If not take a look.
Now, you can wash your car, truck, motorcycle, house windows, boat, airplane or RV and simply walk away, no drying required!!
The CR SPOTLESS De-ionized Water Filtration System gives you the same spot-free rinse system used by new car dealers for years. But, now, at a price you can afford and with the convenience you need to make it work for you!
The DIC-20 provides approximately 300 gallons of mineral-free, de-ionized water based on your input water quality. It consists of two 20 inch de-ionization housings that feature replaceable cartridges that simply slide into the watertight housings. The entire unit is mounted on a powder coated, rust resistant rolling cart that makes it convenient to move into position and store away when finished.
SHIPS COMPLETE, READY-TO-USE
with two 20-inch de-ionizing resin cartridges
hose connectors, battery operated water purity indicator
and assembled as pictured.
Product Description:
Hard water spots can destroy your vehicle's finish. That's why CR Spotless Water Systems created a de-ionizing system that takes out all of the minerals in your water so you can just WASH, RINSE, and WALK AWAY! That's right! With a DIC-20 Spotless Water System, you can let your car, RV, house windows, etc., air dry with no worries that hard water spots will appear. Say goodbye to towel drying and the scratches that towels and chamois can cause. You can even give your car a quick 5 minute rinse between washes to keep it looking great all the time.
Besides cars, de-ionized water is perfect for washing and SPOT-FREE rinsing of your:
* Cars/trucks
* RVs
* Motorcycles
* Boats
* Golf Cars
* House Windows
* Patio Furniture
* Decks
Features:
* A water de-ionization system, not a water softener
* Removes ALL minerals and dissolved solids from the water
* Battery operated, in-line TDS meter to monitor the water quality in and out of the system
* Ergonomically designed cart with a padded handle
* Easy to refill resin or replace cartridges when needed
* Seven pattern garden hose nozzle with FLAT setting
* 4' inlet hose to attach to hose spigot
Benefits:
* Produces 100% pure, mineral-free de-ionized water
* Pure water evaporates without leaving any spots behind
* Know when it's time to change or refill the cartridges before spots appear
* Take it anywhere; easily rolls and maneuvers with one hand
* No need to send it back for regeneration
* Flat spray pattern restricts water flow and increases pressure
* Everything is supplied even the car shampoo and mitts!
System Requirements:
* Standard Garden Hose Bib
* Need to Restrict Water Flow to 4 Gallons Per Minute or Less with Supplied Nozzle on FLAT Pattern or Optional Pressure Washer
Expected Yield:
Input TDS Level Expected Yield (# of Gallons)
50 ppm............. 1600 gallons
100 ppm............. 800 gallons
200 ppm............. 400 gallons
400 ppm............. 200 gallons
Here is what I was thinking:
Regular price: $449.00 for the DIC 20
10 people to start the GB
GB price is $399 free shipping.
Let me know
Ive had one about 6 months now.Its hands down the best car wash change Ive ever made. Those that get it will not believe how clean their car looks after using it. I wash and drive into the garage ...let it dry overnite and absolutely not a spot on it. Even the glass is spotless. The only drawback is the cost of the resin that is used.....pricey....but hell my car is too!!
