Interior cleaning product recommendations
Old 02-29-2008 | 12:33 PM
hal m's Avatar
hal m
Default Interior cleaning product recommendations
Hi,
My son has just gotten his drivers license and is inheriting his sisters 2001 Civic.
The interior is quite dirty and needs a good cleaning/shampooing. The seats are cloth.
What products do you recommend for cleaning and shampooing the carpets and seats?
Thanks in advance for your advice!
Hal
Old 02-29-2008 | 01:17 PM
Stephenwz968's Avatar
Stephenwz968
For general cleaning I like Meguiar's APC plus - you could use Simple Green if you dillute it way down, but APC plus is much less harsh.
Einzett has a great cockpit detailer, but it isn't as strong as a dedicated cleaner. I like Meguiar's Quik Interior Detailer for an over the counter product. HTH
Steve
Old 03-01-2008 | 09:14 AM
TOGWT's Avatar
TOGWT
From: London,UK / Florida US State- Dazed & Confused
Interiors:
All kinds of dust, fumes, smoke and dirt builds up inside of a cars interior, much of it is brought in by the driver and passengers, but traffic fumes and air-borne dirt enters via the vehicles ventilation system.
Every single interior surface is affected. Periodically it needs to be thoroughly cleaned to remove pollutants and preserve the original surfaces, ensuring the vehicles like-new condition. The surfaces involved in this cleaning are; glass, vinyl, leather, plastics, fabric, carpets and various acrylic surfaces.
(See Section 10)
To remove stains the surface tension that bonds them must be released, then the stain encapsulated and held in suspension to be removed. I’m repeatedly asked which product is the best interior cleaner. There is no one-product answer; as the so-called all purpose cleaners (APC) do not remove every stain, different stains require different solvents to remove them.
When cleaning a stain, try detergent and water first. If this does not remove the stain, then try a stronger type cleaner) once fabric is clean apply a fabric protection (303TM High Tech Fabric Guard) Between these cleaners you should be able to remove 99% of stains occurring in a vehicle and around the home; Start with a 10:1 solution and decrease dilution as necessary;
Carpets- 303™ Rug / Upholstery Cleaner & Spot Remover or Folex Instant Carpet Spot Remover
P21S Total Auto Wash (its active ingredient is d-limonene (citrus) a safe all purpose cleaner (APC)
Woolite® Heavy Traffic Carpet Foam or Hoover Deep Cleansing Carpet/Upholstery Detergent
Fabric seats - 303™ Rug / Upholstery Cleaner & Spot Remover or 303™ Aerospace Cleaner
Vinyl interior trim cleaning- the interior trim consists of the dash, vents, hard plastic surfaces and vinyl trim. These surfaces all can be cleaned using a damp micro fibre towel and a 5:1 Woolite / distilled water solution and with a water-based, anti-static cleaner Iz einszett Cockpit Premium; even at high temperatures, its thermo-stable action protects the product against break-down or 1Z Cockpit Premium as a matte finish dressing. Alternative - Einszett Vinyl-Rubber Care + Protectant 'Tiefenpfleger'
Plastic - For all plastic surfaces (BTI Chemicals Plexus® Plastic Polish & Cleaner) including wood, as they are protected with a urethane clear coat
Leather – a 6:1 solution of LM Soft Cleaner and distilled water and Leather Master Protection, as a shield against stains etc
Washable surfaces - Distilled water / Woolite 10:1 or 303 Cleaner & Spot Remover ™
Glass surfaces - Stoner's Invisible Glass and a (Norwex) glass cleaning cloth with a super tight knit.
Headliner - Duragloss 451 Fabric & Carpet Cleaner Aerosol Foam (FC) Is a blend of surfactants, which gently foam away soil, oil and grease from fabric and carpet surfaces. Spot cleaning can be done without leaving rings on fabrics, carpet and velour - http://www.seriousperformance.co.uk/...oView_248.html.
Wood surfaces – Klasse or Zaino All-In-One (AIO)
Ultra violet (UV) protection - for all interior surfaces- 303™ Aerospace Protectant or
Optimum Protectant Plus
Fabric / Carpet Protection – 303™ High Tech Fabric Guard, 3M Scotchgard™ Fabric protector Fluorochemicals (polymer latex) are mostly inert so by applying it to fabric it can be protected from stains and soiling.
Leather Protection – Leather Master’s Protection
Ultra Violet Protection (UV) - 303™ Aerospace Protectant
Old 03-01-2008 | 10:47 AM
jbossolo's Avatar
jbossolo
How about to clean and protect CF interior pieces from UV damage, would 303 work on that too?
Anyone with experience using this or any other product in CF?
Old 03-03-2008 | 06:43 AM
TOGWT's Avatar
TOGWT
303 will also provide UVR protection for corbon fibre
Quick Reply: Interior cleaning product recommendations
