Cleaning Alcantara
From: London,UK / Florida US State- Dazed & Confused
Ultra suede (Escaine, Alacantra):
Is a 100% Polyester man-made suede substitute, which should be cleaned by brushing the nap with a soft nylon upholstery brush, remove pilling with a single-sided razor blade and then applying a cleaning solution (Water /Woolite® or Dreft® with a ratio of 5:1 or stronger) on to an applicator pad and apply to one area at a time (do not over-wet the fabric) and do not use steam.
Localized stains can be treated with a d-limonene (citrus) based cleaner (P21S Total Auto Wash) ensure surface is dry before use by leaving window cracked/open or SONAX NTS7 Upholstery Cleaner for BMW, Porsche and Mercedes-Benz Alcantara materials. Do not use alcohol or strong solvents.
For heavy stain removal- 1:1 Folex Instant Carpet Spot Remover / Distilled water- http://www.folexcompany.com/
Identifying characteristics- very soft to the touch will scratch or scuff very easily; water drops will darken the leather but it returns to its original colour after drying.
Maintenance- Use a soft brush lightly to remove dust and raise the fabrics nap, once your seats / steering wheel / interior is clean, you should use a conditioning/protection product (303™ High Tech Fabric Guard, which includes UVR protection)
