Grease on carpet from seat rails?
I have just finished repairing my power seat, installing a new rubber stop washers for the travel screws, and notice that the light grey carpet is stained near all the seat rails with grease.
Can this be done without a steam machine or wet carpet cleaner as I don't have either.
Thanks,
Dan
Thanks,
Dan
From: London,UK / Florida US State- Dazed & Confused
Try (Simple Green® Aircraft & Precision Cleaner) - http://industrial.simplegreen.com/ind_prod_ext_mor.php plus hot water and a sponge
Thanks for the help!
Try Autoglym Interior Cleaner and follow it up with a steam cleaner if really bad.
More on Extreme Simple Green:
Thank you for contacting Simple Green and for your interest in Extreme Simple Green® Aircraft & Precision Cleaner. In your area Extreme Simple Green® can be purchased through Grainger Supply (www.grainger.com). Grainger has a location in Philadelphia. If you’d prefer a direct shipment you could also try Aircraft Spruce (www.aircraftspruce.com), MSC Industrial Direct (www.mscdirect.com) or
RS Hughes (www.rshughes.com).
We also have a retail product that is very similar to the Extreme Simple Green® which is available at select Home Depot’s. The product is called Simple Green Pro HD and is also a non-corrosive cleaner and degreaser that is safe for use on metals and plastics and is similar to the Extreme Simple Green® Aircraft & Precision.
In addition to the enclosed information I have attached a uses & dilutions chart that applies to both the Extreme Simple Green® and the Simple Green Pro HD.
I hope that this information is helpful to you. If you have further questions about this or other Simple Green products or uses, please feel free t contact me directly. My contact information is provided below and my regular business hours are Mon thru Fri from 8 – 5 Pacific Standard Time.
Thank you again for your inquiry.
Sincerely,
Theresa R. Provolt
Technical and Customer Liaison
Simple Green
15922 Pacific Coast Highway
Huntington Harbour, CA 92649
(800)228-0709 ext 6091
Sincerely,
Theresa R. Provolt
Simple Green
