Problem, Need Help?!
Location: 40 min South from the 'Ring, 45 min East of Spa
Alright here is my situation. My Atlas Grey 987S' front end, mainly bumper, has bug guts that I am unable to get out even after many washes. Tried clay but that doesn't seen to help me. Anyone have some helpful suggestions as it really bugs the crap out of me to see a silky smooth car and then look at the front bumper and cringe at the residue still in my paint.
Thanks in advance!
Thanks in advance!
Premium Sponsor
Try using Zymol Strik. It's a safe citrus cleaner. You'll apply it to the front, let it sit for about 5 min. and then rinse off and clean with wash mitt. Great stuff to clean the engine, wheel wells, etc. PM me if you want a bottle.
I've been using bug and tar remover made by RainX and the results are excellent. If that doesn't work try using a clay bar, that will work
Are these bug remains or is it bug etching ?
If etching, caused by the caustic nature of bug guts, then nothing will remove it....short of a wetsand and polish or a repaint.
Anthony
Anthony
Extreme Simple Green works great. Mix 1 qt of SG to 3 qt of water and spray on. They wipe off easy with a sponge wash. On cars that bugs have been on awhile, there will still have some residue. A wet micro-fiber towel will take care of the rest. This is my car after a trip to the Texas coast last weekend
More On Extreme Simple Green from the Manufacturer
Thank you for contacting Simple Green and for your interest in Extreme Simple Green® Aircraft & Precision Cleaner. In your area Extreme Simple Green® can be purchased through Grainger Supply (www.grainger.com). Grainger has a location in Philadelphia. If you’d prefer a direct shipment you could also try Aircraft Spruce (www.aircraftspruce.com), MSC Industrial Direct (www.mscdirect.com) or
RS Hughes (www.rshughes.com).
We also have a retail product that is very similar to the Extreme Simple Green® which is available at select Home Depot’s. The product is called Simple Green Pro HD and is also a non-corrosive cleaner and degreaser that is safe for use on metals and plastics and is similar to the Extreme Simple Green® Aircraft & Precision.
In addition to the enclosed information I have attached a uses & dilutions chart that applies to both the Extreme Simple Green® and the Simple Green Pro HD.
I hope that this information is helpful to you. If you have further questions about this or other Simple Green products or uses, please feel free t contact me directly. My contact information is provided below and my regular business hours are Mon thru Fri from 8 – 5 Pacific Standard Time.
Thank you again for your inquiry.
Sincerely,
Theresa R. Provolt
Technical and Customer Liaison
Simple Green
15922 Pacific Coast Highway
Huntington Harbour, CA 92649
(800)228-0709 ext 6091
Sincerely,
Theresa R. Provolt
Simple Green
