Water deionizer
Costco usually has the best prices on the CR spotless and the resin bag refills. the CR has a built in water hardness tester. totally worth it. If you consider DIY, getiing as close to
0ppm hardness is basically what you should be after.
Received 5,388 Likes
Look into Rennlister Matt's offering at Obsessed Garage.
The ones that use coils are bull**** as the effect only works within feet of the unit and dissipates. I just put a water softener in and it can be done reasonable. Had the CR but the water pressure was so low and changing resins a hassle. I'm posting on this topic on a new thread.
we have a softener and it makes washing (and cleaning the house / bath) super easy. Detailer I know down the street with a small shop, he does full RO, but he has a 250 gallon tank with a pump for washing the cars as the process for fully deionized water makes pressure pretty low and especially at the volume he uses it.
Also, it's not the water pressure of the pressure washer that matters. It's the flow rate (GPM). Many electric pressure washers have high pressure (like 2,000psi+), yet low flow rates, like 1.2 GPM. You really want something with a higher flow rate.
I've had my CR Spotless unit for 6 years now. I've only had to replace resin 2x's and I wash at least one car a weekend. I don't understand how it's actually lasted so long, but I do a TDS test weekly with a meter seperate from the built in one. It's single handed the best vehicle washing product i've ever bought.
ironically, my TDS out of the tap is generally in the 300 hundreds. But for some reason I can always make the resin last longer, not sure what the reasoning is. I also have a separate RO/DI unit for my fish tanks, i get 3-4x out of it compared to what other people see.
Good to see another bay area local
