Sponsored By:
Sponsored By:
how do you wash the roof of your cayenne?
Old Mar 27, 2026 | 02:43 AM
ThomasWShea's Avatar
ThomasWShea
Default how do you wash the roof of your cayenne?
i am 6’ 2” w 38 inch arms and i cannot reach the center - so this has to be a common issue. i was going to buy a washer thing w an extending pole but thought i would ask what people are using first.
Old Mar 27, 2026 | 02:57 AM
MSCA's Avatar
MSCA
I use a 12 inch step stool for that as well as for the center of the windshield.
Old Mar 27, 2026 | 07:50 AM
mafpolo's Avatar
mafpolo
I use a small 24 inch ladder that allows me to get wherever I need to on the Cayenne. I don't want to use a wanded brush. I want to use my microfiber pad...hence the ladder.
Old Mar 27, 2026 | 08:22 AM
PHX's Avatar
PHX
Crack open the back or front door, stand on the door sill and use your wash mitt/pad. I do the same when I dried the roof.
You can easily wash and dry the door sills and frames if you want to, while you have the door(s) open.
Old Mar 27, 2026 | 09:26 AM
Dgjo2020Turbo's Avatar
Dgjo2020Turbo
Lower suspension to sport+ and you’ll easily reach the entire top.
Old Mar 27, 2026 | 09:28 AM
MSCA's Avatar
MSCA
That’s a good idea if one has air suspension, will try it next time.
Old Mar 27, 2026 | 08:05 PM
aklim69's Avatar
aklim69
Drive through the car wash?
Old Mar 27, 2026 | 08:12 PM
Kendo67's Avatar
Kendo67
Just let the butler do it , saves faffing around with steps etc.
K
retom's Avatar
retom
Thomas, you have a Coupe, so your Cayenne has a glass roof. Coat it with a hydrophobic agent like a car window treatment (RainX, etc.). Then, simply rinse it with clean, pressurized water and the roof will be clean.
Old Mar 27, 2026 | 09:30 PM
Poppyboy's Avatar
Poppyboy
Step stool is great for all things, including this!
Old Mar 29, 2026 | 11:36 AM
Slow Guy's Avatar
Slow Guy
Veteran: Navy
I have one of those 18” high and about 3’ long steps but it’s still in storage until I finish getting the garage cleaned up so presently I use one of those extendable wand wash mit, works pretty well for me. I only use it for the roof and the first pass on the windshield but I’m quite happy with it.
Very similar to this:
https://www.harborfreight.com/40-in-...orm-56203.html
Old Mar 29, 2026 | 11:38 AM
MSCA's Avatar
MSCA
How do you dry the roof then, if you can’t fully access or see it?
Old Mar 29, 2026 | 11:43 AM
Slow Guy's Avatar
Slow Guy
Veteran: Navy
I’m 6’2” so I can see it just reaching the middle with the wash mitt is difficult. To dry I start with the blower and finish off with a big microfiber towel, I get the vast majority of the water off.
Old Mar 29, 2026 | 12:07 PM
Kevin_'s Avatar
Kevin_
I am 6’ and I try to stay off ladders now so I use this Girot’s wash mop on an extension pole after a prerinse and foam with the P/W. I use it on the roof, windshield and hood, works well, then change over to their wash mitt. I use a blower and microfiber towel to dry also.
https://www.griotsgarage.com/wash-mop-stick-kit/
https://www.griotsgarage.com/microfi...itts-set-of-2/
Old Mar 29, 2026 | 07:07 PM
TeesTurboS's Avatar
TeesTurboS
At 6'4" and 37" arms, I can just reach enough from both sides to completely get the entire roof line on my 2022 Turbo GT. I was also able to do this on my 2022 GTS SUV body style, too.
