how do you wash the roof of your cayenne?
I am 6’ and I try to stay off ladders now so I use this Girot’s wash mop on an extension pole after a prerinse and foam with the P/W. I use it on the roof, windshield and hood, works well, then change over to their wash mitt. I use a blower and microfiber towel to dry also.
https://www.griotsgarage.com/wash-mop-stick-kit/
https://www.griotsgarage.com/microfi...itts-set-of-2/
i can reach the center, but i have to lean in such a way to where i am making contact w the car - and i dont like doing that because it is a scratch risk.
thanks all for the input. i was hoping someone would have some idea i didnt think of but this is just a good old fashion issue w a basic resolution of getting myself up higher or getting a longer washing implement.
@Kevin_ yes i was thinking of going w something like this.
Thomas, The Girots extension pole is aluminum so you could damage the paint if hard contact was made. I like it because i can be away from the car and stay drier while washing, it is fast compared to moving a ladder side to side or opening your doors (then I have to wipe off the door sill). My wife likes that I am not on a ladder, so happy wife, more car stuff!
I've never hand washed a car but once in my life over 35 years ago so I may be off base here. Can't you buy a pool noodle, cut it down the length, slip it onto the pole and and zip tie to tension it in place? I suppose it would be OK for all that trouble if you are doing it on a regular basis?
MSCA, a wood pole could work too.
That wooden pole might work.
