Sponsored By:
Sponsored By:
9Y0 Drains
Old 09-30-2024 | 03:15 AM
RennHou's Avatar
RennHou
3rd Gear
Default 9Y0 Drains
Hi all, does anyone have a diagram of all drains on a 9Y0.1? Specifically curious about the rear sunroof drain. I was only able to find one on passenger side between back of wheel arch and rear bumper (no hose in equivalent position on drivers side). What’s the best way to keep the rear sunroof drain clean? Thanks in advance
Old 09-30-2024 | 08:15 AM
matthewr87's Avatar
matthewr87
When I was at the dealership for some warranty work the service manager proposed I agree to let them do a drain cleaning for $600......
So you have that option I guess
Old 09-30-2024 | 08:31 AM
chassis's Avatar
chassis
There are four sliding roof drains, one in each corner of the trough surrounding the sliding roof panel. Exit points are near the tires.
Don’t park under trees
Park in a garage
Test for water flow through the drains periodically by pouring a cup of water into each corner of the sliding roof trough and observing water exit near the corresponding tire
If necessary use appropriately sized string trimmer (weed whacker) line to push into the drain to clear it.
The following 3 users liked this post by chassis:
JSchilberg (09-30-2024), Needsdecaf (09-30-2024), Schnave (09-30-2024)
Old 09-30-2024 | 01:10 PM
RennHou's Avatar
RennHou
3rd Gear
Thanks Chassis. How do you access the two rear drains? Does pano roof have to be removed?
chassis (09-30-2024)
Old 09-30-2024 | 01:53 PM
retom's Avatar
retom
This is from an Audi Q7/Q8. Since it is the same chassis design, I assume that in Cayenne is the same.
You can clean the rear drain from the bottom after removing wheel housing liner.
Old 09-30-2024 | 02:37 PM
chassis's Avatar
chassis
Open the pano roof all the way
remove your shoes
Enter the vehicle and assume a standing position through the open pano roof with one foot on each front seat.
Look in the forward two corners and identify the two ~4mm drain holes.
Turn your body through 180 degrees, look in the rearward two corners and identify the two ~4mm drain holes.
Old 09-30-2024 | 05:15 PM
PHX's Avatar
PHX
Originally Posted by chassis
remove your shoes
Who wears shoes? LOL
Quick Reply: 9Y0 Drains
