Infamous Coolant / Water Pump Failure w/ Coolant Leak into Vacuum System - How often?
Just took my 2020 CPO base in for annual service. I don't know why I do this but I change my oil at half cycles but take it at the service interval for them to give it a once over. Well, I'm glad I did.
69kmi and the water pump is leaking. Thankfully under warranty but "excited" to see how much this repair would have been out of pocket.
I asked the advisor, is this normal or abnormal. "Normal, about this mileage". Good god. I would hope that Porsche would fix the design. 70k miles is too soon for a part like the water pump to fail.
I had to change one of my Turbos on my 2019 Cayenne S, and the replace cost for just one was $8,000+...
They are not maintainable, so when the vacuum exterior metal handle broke on one, the whole Turbo had to be replaced..
They found indications of a leak, dried pink coolant originating from the water pump, during an inspection of the car. i would post a clip from their walkaround video but i can’t get it small enough!
I had no indications of leak or CELs. ill double check the garage for drips.
chassis (09-25-2024)
I have a question on this topic. is it possible with a water pump failure that the vacuum system does not get contaminated? Or what if it was contaminated and the vacuum system wasn’t replaced and just a new water pump was installed? i am looking at purchasing a 2019 Cayenne Turbo that had the water pump replaced about 1,000 miles ago but the owner says they did not replace the vacuum pump or hoses. The repair was also not done at a Porsche shop.
After two years, many of these batteries begin to fail..
Porsche reduced the defective battery prices from a ripoff $2,000 to $1,000, but still charges $1,000 for simple installation/registration labor..
Or, you need to know that there is the Lithium to AGM battery conversion for around $500..
Each Turbo side costs $8,000 to change since they are not maintainable, so make sure they are working fine..
Battery was also recently replaced.
I haven’t heard or read of Turbo issues. $8,000 a side! Yikes, I starting to thinking I’m looking at the wrong vehicles. We did just purchase a new Tesla and I have to say beside the insane acceleration the fact that I never need to worry about doing another oil change along with all the potential stuff going bad, is a real pleasure. Maybe a Cyber truck instead! 😂
There are reports on rennlist and audiworld where water pumps are replaced with no vacuum components replaced, and with the vacuum solenoid replaced but not the vacuum pump.
All combinations of scenarios are possible. The important thing is to keep an eye on the water pump and get it replaced, preferably under warranty, as soon as possible.
Here are some snap shots from the walkaround video. These show dried coolant, from underneath the car, originating from the water pump and drying on the alternator and belt tensioner. Something to look for, especially since this seems like an early catch. Correction: I have no idea if this is an early catch or not. *shrug*
pink dot on tensioner housing
pink dot on alternator
water pump pink stuff
The following 3 users liked this post by damaja:
Great photos, thanks for posting them!
Yes it's possible.
chassis (Yesterday)
Thermostat and coolant shutoff valve failures are also reported. Similar story - seal failure where time and usage are both factors.
