Sponsored By:
Sponsored By:
Help identifying cable
Old Dec 27, 2023 | 01:54 AM
YeetItToTheLimit's Avatar
YeetItToTheLimit
Default Help identifying cable
Need help identifying this blue cable found in the back left luggage compartment fuse box area of a recently purchased 2019 Cayenne.
Connectors seem to be male/female meant for each other but I haven’t noticed anything not working on the car so I am unsure as to what the blue wire is for.
Old Dec 10, 2024 | 04:47 PM
Cyua_rc's Avatar
Cyua_rc
I just found out mine is also unplugged like yours. Did you ever figure out what it is?
Old Dec 10, 2024 | 07:00 PM
retom's Avatar
retom
These types of connectors are typically used in VAG cars to connect interior and trunk lights.
Old Dec 11, 2024 | 10:11 AM
Woofman's Avatar
Woofman
The following post shows where the optional cargo area mounted CD/DVD changer was in the 2019 Cayenne: https://rennlist.com/forums/cayenne-...l#post17532638
Old Dec 11, 2024 | 10:38 AM
retom's Avatar
retom
The CD changer has a multi-pin connector (6 pins) and optical fiber sockets.
Old Dec 11, 2024 | 10:50 AM
Schnave's Avatar
Schnave
I’ve also ruled out connectors for the motorized trailer hitch (used in the EU). Those two connectors are 6 pin and 10 pin. Those pictured appear to be single wire connectors.
Old Dec 11, 2024 | 01:54 PM
Woofman's Avatar
Woofman
I see one of the two connectors but in my 2022 Cayenne it is connected to another connector. I assume these connectors are for features that my Cayenne has but some others don't have.
Here is a list of the features my Cayenne has which you can use to compare against the features on others that have these connectors unused.
Old Dec 11, 2024 | 01:58 PM
retom's Avatar
retom
Disconnect this connector and see what stops working
Old Dec 11, 2024 | 03:28 PM
Woofman's Avatar
Woofman
Sure, stay where you are until I report back on what happened.
