Cayenne e-hybrid charging schedule
#31
how long does it take to charge from empty? if it takes more than 3 hours you have the 3.6 kW on board charger - if it charges from empty in less than 3 hours you have the 7.2 kW onboard charger - also the window sticker should tell you - if 7.2 kW is not listed anywhere then you have the 3.6 kW on board charger.
#32
#1 trying to outguess Porsche as to what is "better" is a losing game - they have more data than you have - my opinion is drive the car how you like and dont' worry about "better" - and besides your "better" may not be the same as my 'better" - what are you optimizing for in terms of better? fuel economy? not waking the neighbors early morning? fun? performance? engine hours? speed? cruise? cabin temperature? what is better in your mind? total EV hours? distance/range? wanna get home with a full tank of gas (I drive to the gas station on full ICE, and then drive home in pure EV mode so the car is 100% full in the morning both battery and gas fuel tank) - what are your goals for 'better"?
#2 no - it will always start in eMode
P.S. By the way I am surely not doubting Porsche they surely know more
daveo4porsche (10-25-2023)
#33
Dave, I agree with you "better" is a very abstract word. I guess I am trying to understand more about the differences and in addition - if it was possible - to leave it permanently to one setting for my wife - which seemed hybrid mode is angood choice. But anyway it seems after the battery runs out at 5% on e-power mode it turns automatically to hybrid (auto) so all good
my basic point is - don't overthink it - porsche has it pretty well sorted in my opinion and the car/hybrid seem to "just work" - so trying to think about things/modes/defaults that Porsche hasn't thought of is a losing battle - so just get it in an drive, and if you want to help the ICE motor get started sooner just one click to hybrid-auto or two-clicks to sport - and generally speaking that's as much as one really needs to do - but mostly just leave it alone and let the car do it's thing…since April of 2021 I've found the car basically just works and I don't need to play the what mode do I want game ever if at all.
#34
daveo4porsche (10-26-2023)
#35
#37
I think it’s a good question as the Cayenne manual advises not using E-power continuously -
- Porsche recommends the use of the electric and conventional drive in the best possible balance. Continuous and exclusive movement of the electric drive can result in increased wear on the high-voltage battery.
Last edited by cpthavoc; 06-22-2024 at 07:33 AM. Reason: Please delete this as second comment the edited version. Apologies for hassle
#38
A couple of more questions by the wife:
1) The car always starts in e-power. Is it better use this for short communes in the city or better to use hybrid (auto) mode?
2) Can you set the car to always start in e-hybrid auto mode or even sports or sports plus? This is an E.2 car, have not checked the settings yet. (Manual states this: The E-POWER driving programme is activated by default and allows purely electric driving. After the ignition is switched off, the selected driving programme is automatically reset to E-POWER if the prerequisites for this driving programme are met.)
In response to two comments above - I think it’s a good question as the Cayenne manual advises not using E-power continuously
#39
Try this — Tap the schedule you wish to delete and swipe right to left. It will delete it.
A good resource is the online PCM simulator. You can choose between Taycan and Cayenne. It is skewed towards the European market and features such as Sirius XM are not available. Otherwise, a great tool for poking around all the screens and learning the system.
https://your-digital-co-pilot.com/en
