Sponsored By:
Sponsored By:
Arm rest cover install
Old 08-05-2023, 07:31 PM
cdh993
cdh993's Avatar
Default Arm rest cover install
Has anyone successfully pried off their arm rest cover out there? I have a MY 22 and purchased a new cover with embossed crest. Trying not to break anything, thanks for any tips.
chassis (08-05-2023)
Old 08-05-2023, 11:00 PM
Schnave
Schnave's Avatar
Received 2,504 Likes on 1,326 Posts
@mjamesp13 replaced his. We discussed it in this thread:
https://rennlist.com/forums/cayenne-...ft-****-2.html
I’ll summarize: Lift the armrest to gain access to the trim plate. Use a trim tool in the positions shown below to pry the bottom of the trim plate up and forward. You can use just one trim tool — two shown for clarity.
Careful when removing the trim. There are small wires attached to the microswitch.
Remove the four bolts, circled. You may have to pry the rear ventilation console back to facilitate armrest removal. According to @mjamesp13 it is a tight fit.
The following 2 users liked this post by Schnave:
chassis (08-05-2023), Palantir (08-05-2023)
Old 08-05-2023, 11:41 PM
cdh993
cdh993's Avatar
Thanks for sharing, the piece I bought from a dealer online is just the top cover that appears to snap on in some way. It doesn’t seem like you would have to unbolt the entire arm rest? I’ve tried a pry tool but with no luck yet.
Old 08-05-2023, 11:46 PM
chassis
chassis's Avatar
Received 1,323 Likes on 973 Posts
In the photo it looks like 4 attachment points from the cover to the cover support/pivot arm.
Can you post several more well-lit and clearly focused photos of the new cover, showing the details of what appears to be the 4 attachment points? If there are no threaded fasteners, prying and un-snapping is the procedure to remove the cover.
Old 08-06-2023, 12:08 AM
Schnave
Schnave's Avatar
I didn’t realize you could buy just the top cover. That’s great news, as I scuffed mine and may need to replace it if it cannot be repaired.
May I ask how much the cover cost? That will help my decision whether to repair or replace.
Please keep us updated with any techniques you discover.
Old 08-06-2023, 10:16 AM
chassis
chassis's Avatar
Until you provide us more photos, my guess is to start at the front (latch) side with two trim wedges between the cover and release latch. Twist the wedges to unsnap the two front clips, then either move to the rear and repeat the process, or simply slide the cover rearward with no usnapping of the rear clips needed.
Plan for broken clips in the process. This means you need to buy them in advance, after of course identifying the part number and a source. Or remove the cover, breaking clips in the process, then find and buy new ones.
If it was me I would take the embossed cover to all the dealers in my area and ask the parts guys to sell me clips. Who cares if they charge 200% markup? It's a $3 part (per clip).
cdh993 (08-06-2023)
Old 08-06-2023, 02:26 PM
cdh993
cdh993's Avatar
It was just over $300 compared to the full cost of whole unit. It has to pry off but haven’t been able to yet. Too hot!
The following 2 users liked this post by cdh993:
chassis (08-06-2023), Schnave (08-07-2023)
Quick Reply: Arm rest cover install
