What is the purpose of the right trunk button (the one with the picture of a key)? The left trunk button you press once and the trunk closes. The right trunk button I
press once and it closes halfway and I have to press it two more times for it to fully close.
Might be defective, AFAIK.
The right should close and lock the vehicle if it’s unlocked. The left will close and not lock the vehicle if it’s unlocked. If the car is already locked both leave it locked.
First, make sure you have your key fob in hand or on your person.
Reset the hatch by opening it all the way. If necessary, push it up to the stop by hand.
Then press and hold the left button a few seconds until you hear it beep-beep.
Then press and release the right Close & Lock button. Remain near the rear of the vehicle (with key fob) until the hatch is closed and latched. The hatch should now close all the way and lock the vehicle.
Let us know if that worked for you.
Note: After the reset, if you wish to set the opening height to a lower position, open the hatch, then manually set it to the desired height. Press and hold the left button a few seconds until you hear the beep-beep. That position is now memorized.
that closes and locks the car. You likely don’t have the key fob on you or close enough.
that seemed to have worked. Thank you. Is it ok to manually force the hatch to the desired height? I feel like it’s going to break lol
i try it but without any luck. Key fob is in my hand tailgate is full open. I hold the left button till sound 2x beep. After that I press the right button. Tailgate don‘t close and lock. It stops after few second
Possibly it's the detection of the key being inside vs outside that's pausing the closing action. If the car thinks the key is inside it might not close. Something to test, anyways.
I've also had this happen a couple of times but always assumed that it was due to near obstacles (I park in a rather constrained parking space).
I test it with key in- and outside, i also put the key far away. Same issue. Button 1 works also by left key inside, tailgate close directly.
