Wheel Bolt Torque
Wheel Bolt Torque
Does anyone know the wheel bolt torque for Cayenne GTS with 21” wheels?
118 ft lbs for all wheel sizes. Use a 19mm hex socket. Lock bolt key located in tool kit with spare tire.
From the latest Porsche Approved Wheels and Tires Manufacturer’s Certificate, attached.
The following 8 users liked this post by Schnave:
3-Pedals (08-05-2022),
8378hjlafdljfads (08-12-2022),
ArcticFox (08-06-2022),
bobblehead (08-05-2022),
chassis (04-10-2023),
and 3 others liked this post.
Are these the security bolts pictures above the only version Porsche offers? The ones with the serrated head.
Does Porsche offer a tulip-floral type (like MB, Toyota, etc.)?
Off topic, I recently changed my wheel to put spare on as the tire needed to be patched. When loosening the bolts from the wheel (and they were never removed before), I realized they were not torqued properly at all. Their torque was slightly above 90 ft lbs, far shy of the 118 ft lbs. When I get a chance, I will stop by the dealer to point this out and see if there is an explanation. They were the easiest lug bolts that I had to break loose (and I use a 4 ft breaker bar not impact) so I know how it feels between various torque figures. To check the torque of the existing bolts, I used a different electronic torque wrench that reports the torque value as it is applied and remembers the highest value. Every bolt was between 90 and 93.
Yes, 118ftlbs, but almost all Porsches I’ve seen for many years have 19mm wheel bolts there was someone on one of the other threads that has a GTS with 17mm bolts. So best to check.
- When tightening, you are stretching the bolt which requires additional torque. Total torque includes thread and bolt face friction plus bolt stretch torque. When loosening, torque includes the same thread and bolt face friction minus bolt stretch torque.
- After tightening, the materials fatigue and compress due to clamping force. The actual clamping force — and the torque required to loosen the bolt — will be less than immediately after the initial installation.
https://www.boltscience.com/pages/a-...g-of-bolts.pdf
911car (12-14-2022)
Received 4,196 Likes
True story...
I always put winter wheels and tires on my wife's ride and whatever my winter ride of choice is. And I always do them in my garage. About five years ago I am doing the winter wheel swap on her Audi SQ5 and its freezing cold in the garage, plus she came out at least three times interrupting me about the news of the day, or what salad dressing I wanted for dinner, etc...which caused me to lose track of where I was on torquing the lugs. I have a very specific routine which was interrupted. Five days later she is headed home from work on the Fairfax County Parkway and she very calmly called me on her cell "My left rear wheel came off the Audi at 50 mph and it rolled about a half a mile down an embankment".
WHAT?!?!? ARE YOU ALRIGHT? DID YOU HAVE A CRASH? I was beyond stunned. The SQ5 rode straight up on three wheels and she was able to pull over on the shoulder with zero damage to the vehicle. AMAZING. I immediately left work, ran home to grab two floor jacks and one of the summer wheels/tire and found her on the side of the road, with a Fairfax County Pumper Fire Truck with all its lights ablaze "rescuing" her. How embarrassing. Of course the Firemen were all laughing at the knucklehead husband who didn't torque the lugs on that one wheel. They even went and recovered the lost wheel while I put the summer one back on. It took a while before she trusted me to work on her car again.
So, since that day my NEW routine is to do all wheels twice. I go around the car and do all four, then go around again. If I get interrupted, I go around one more time.
Originally Posted by drcollie
True story...
When swapping wheels, I never put the center caps back on until I have completed the torque sequence. 😉
True story...
chassis (12-15-2022)
I hear ya
True story...
Thanks for sharing!
My routine is to torque during installation, reset tire pressure monitoring system, go for quick drive to let it reset and then check torque again. Not missed a bolt or a wheel, yet!
I won't know until later this week if I will be buying a second security socket to match the now beat-up one I recovered or if I will buying four new security lug bolts and two new security sockets that fit them.
So ... if you're cautious (or paranoid like me), you might want to check to see if a replacement security socket for your particular locking lug bolts is still available and perhaps obtain one. The code for the security socket is etched in the metal inside the socket.
Do the security bolts actually do anything beyond slowing down a winter wheel swap? Is a thief coming prepared to steal your wheels going to skip a car with a security bolt? Do thieves even steal wheels, or is it just easier to take the whole damn car? If I didn't care about re-using the bolt I could pound on a disposable socket head and have that bolt out only 10 seconds slower than the other 4 bolts.
