Sponsored By:
Sponsored By:
2022 Cayenne Battery
Old 03-07-2023, 07:53 AM
  #46
kash1786
kash1786's Avatar
Unhappy LiPO4
I give up with Lithium battery's. Sent the car to have tints fitted and black out the chrome, and lo and behold the Lithium battery dropped voltage, and is now in safe mode. Cayenne (2019) only starts with a jump start, but when started has the red electrical fault error, and switching it off kills everything. Battery seems to be stuck in 'safe mode'. Tried connecting the NOCO charger up, and its not detecting any voltage so not charging. There HAS to be a way of getting the AGM in!
Tried waking the battery up by connecting to a healthy 12v battery, but no luck !
Old 03-07-2023, 08:26 AM
  #47
drcollie
drcollie's Avatar
Received 4,204 Likes on 1,483 Posts
a regular charger or a 12v battery won’t work, you need a booster with a surge feature to wake up the battery. One like this, and press the red exclamation point to bring the battery out of sleep mode.
NOCO Boost HD GB70 2000
Amazon Amazon
kash1786 (03-07-2023)
Old 03-07-2023, 08:54 AM
  #48
Schnave
Schnave's Avatar
Received 2,618 Likes on 1,373 Posts
If you can’t get the BMS to reconnect with a booster, there may be another possibility: the BMS may have permanently disconnected the battery.
We’re all familiar with the battery going to sleep when the voltage drops below 10V or 15% State of Charge (SoC). Boosting or jumping the battery will reset the BMS and allow charging again.
But the battery can also go to sleep permanently (sleep with the fishes) if the voltage drops below 6.5V or exceeds 18V. The logic: The cells have been damaged by the extreme voltage and may cause a hazardous malfunction if used again.
Porsche says the battery also disconnects when the battery is overheated or is short circuited. Any chance the shop dropped a wrench across a hot terminal?
Another possibility: The BMS circuitry has malfunctioned. Luckily, it is replaceable. Another member had his replaced and restored the battery to normal operation. Important: prior to replacing the BMS, check the internal battery voltage is between 6.5V and 18V. If outside those limits, your battery is fried.
File Type: pdf
Old 03-07-2023, 09:36 AM
  #49
kash1786
kash1786's Avatar
Very useful, thank you @drcollie and @Schnave , I've ordered a Li specific charger off Amazon today that has a 'wake up' option, hoping that would work. Bit concerned that the jump start didn't prompt the battery to wake up and start charging from the alternator. Don't have much hope!
No shorting of the battery from what I was told, they said they jumped it from the terminals under the bonnet. Very annoying, as I just got the car back on the road after a major repair on the front (proud to say I did myself- minus the spraying )
Before..
And after!
Old 03-07-2023, 11:21 AM
  #50
dasams
dasams's Avatar
If you turn the ignition to the first position while doing maintenance or just playing with the PCM, the battery will quicker drain and go into low voltage protection mode. Ask me how I know. It's an easy fix to use the surge feature of a booster to reset the system. Please post here if that is successful.
Old 03-07-2023, 12:17 PM
  #51
Needsdecaf
Needsdecaf's Avatar
Received 2,608 Likes on 1,620 Posts
Do the hybrids have the LiPO4 12v battery as well?
Old 03-07-2023, 12:18 PM
  #52
Schnave
Schnave's Avatar
Prior to jump starting the engine again, verify the BMS has reconnected the battery. From your description, it sounds like the BMS has NOT reconnected.
Huh? Then why did it run after I jumped it? Because you don’t need a battery to run a car once it’s started. That’s right — no battery needed. The vehicle runs off the alternator.
Don’t believe me? Check out this fascinating video (well, fascinating for a geek). He disconnects the battery and the engine runs just fine.
However, running a modern vehicle without a battery can damage the delicate electrical systems. In the video, he puts a voltmeter on the alternator output. The voltage goes crazy, ranging from 9V-15V. Can’t be good for the electronics.
So here’s how to check it. Give the battery a good boost at 13V - 14V for a couple minutes. That should wake up the battery. Remove the booster and check the voltage. If it still reads zero, don’t start the engine. You could cause serious damage to your electrical system.
I suspect that’s why you have the RED Electrical Fault message.
Old 03-07-2023, 01:07 PM
  #53
cwazyeurodrivr
cwazyeurodrivr's Avatar
I've had 3 LG Chem 12V main batteries go bad on me from Porsche, in 15 months, 2 of them went bad in 4.5 months. After I sent an e-mail to Porsche USA CEO, VP of customer Experience and got the " executive customer escalations " person on the phone she didn't admit it but said " yeah we are having a lot of discussions around those batteries and in the Taycon batteries are having issues as well "
clearly LG Chem batteries are junk
kash1786 (04-03-2023)
Old 04-03-2023, 07:37 PM
  #54
Surferbum
8th Gear
Surferbum's Avatar
Can you give me the contact information for VP of customer experience? My battery failed and car is 2 months out of warranty so Porsche is reducing to help.
Old 04-03-2023, 08:09 PM
  #55
kash1786
kash1786's Avatar
Interesting to see that this is common! I've asked Porsche to check and order a new battery, which is obviously not it stock. I've put an AGM battery in for now (error code on dash). Tried using the neg battery cable from a panamera with IBS to see if it would work, unfortunately it doesn't. I noticed the LIN plug on my car has a single wire, and the picture recently with factory fitted AGM has 2 wires. So it doesn't work as a plug and play .
Old 04-04-2023, 12:02 AM
  #56
don_musico
don_musico's Avatar
I am just after replacing the LG battery in the service in my Cayenne GTS 2021 year in the Polish Porsche salon. The battery ran out while cleaning the car, due to an urgent trip I put in an AGM battery, which of course Porsche didn't like. They ordered the battery saying they would run the warranty procedure so it won't cost me anything. The battery was supposed to arrive in 4 days. It arrived after exactly 14 days, after many arguments and arguments with Porsche.
Finally, they said that because of me inserting a regular battery, they are unable to create documentation for the guarantor and I have to pay for the battery and, of course, replacement and its coding for the car. Final cost $2,331.27
Old 04-16-2023, 06:08 PM
  #57
JasonZY
5th Gear
JasonZY's Avatar
I just found this post discussing how to re-code the BMS to wake up the battery, anyone tried if this works?: How to Disable Porsche Cayenne Battery Protection Mode?: 車OBDIIツール (seesaa.net)
josephcc (09-07-2023)
Old 08-03-2023, 05:58 AM
  #58
rajatparihar
rajatparihar's Avatar
Yep my 2023 cayenne e-hybrid came with LiFePO4 battery
Old 01-12-2024, 11:54 PM
  #59
unvjustintime
unvjustintime's Avatar
did this get resolved? It appears 992 has one wire external BMS sensor for agm battery but cayenne has two wire. Was your issue with what vehicle and was anything resolved?
Old 01-13-2024, 10:32 AM
  #60
chassis
chassis's Avatar
Received 1,435 Likes on 1,052 Posts
These comments are worth investigating. To convert a .1 with LiFePO4 battery to AGM, it could be required to install a late .1 or .2 negative cable AND LIN harness. Need to dig up information on the design of the late .1 and .2 LIN harness.
Quick Reply: 2022 Cayenne Battery
