6th Gear Shudder/Vibration
#451
I have a 23 GTS and started noting the vibration at about 5,000 miles, so I disagree that it is only related to the V6. I initially thought it was a tire or the road surface, but then recalled this thread and realized it was always when in 6th gear (and a slight vibration in 8th). If I was a passenger and closed my eyes, I could tell you every time it is in 6th, there is a consistent coarseness and roughness to the engine/transmission. The problem is that when in sport, it seems to settle into 6th gear for much of my driving at 40- 60 mph. I did tell my service advisor so that in case there is a fix after the warranty expires I raised the issue during the warranty.
On balance, I like the GTS so much I can live with it. But it is certainly goes in the negative column.
chassis (05-14-2024)
#452
Similar with my 2022 base now with 21,000 miles. The vibration didn’t show up until about the 10K mark but since then I know right away when it’s in 6th gear as I can feel the mild vibration in the steering wheel and base of the seat. The car has had 4 oil changes and that never makes a difference. Only occasionally can I notice it in 7th but never any other gear and it’s not really RPM dependent. Like others, I’m convinced it’s in the hang on transfer box or whatever they call it. So far I can live with it until perhaps eventually a fix. I’ve not reported it to the dealer as they can’t fix “they all do that” anyway and it’s got the extended warranty.
2019 Porsche Cayenne oil burn 150K miles - Rennlist - Porsche Discussion Forums
#453
News About 6th Gear Vibration Problem
Has anyone with this issue heard anything similar? I’ll be bringing my car in for the repair in a couple of weeks, and will report back after it’s done.
chassis (08-07-2024)
#454
My 2022 base has had the 6th gear vibration problem since about 10k mi. It’s now got 30k mi and the problem persists. I cannot stand it and have started looking to replace the car. But today, I was told by an SA at a major (read: very large) dealer that Porsche is aware of the problem and has authorized the dealer to repair the car under warranty if a customer complains. When I asked if the repair was replacing the transfer case, I was told it’s not the transfer case but rather the transmission mount. I was also told (1) there’s a service bulletin about the problem, and (2) the repair doesn’t entirely eliminate the vibration but significantly reduces it.
#455
Yes, that’s true. But as I recall, the people reporting it also said the transmission mount replacement didn’t work or stopped working. Then, others reported it was the transfer case. But no one, to my knowledge, reported that Porsche N.A. acknowledged the problem or agreed to cover the repair under warranty. I myself some months ago had Porsche N,A., through another dealer, refuse to repair the car. What’s different this time is the news, if it’s true (I won’t believe what I was told until I see it), that Porsche acknowledges the problem and is covering it.
#456
#458
#459
6th gear vibration update - good news!
As for what the dealer did to the car, I don’t know yet. The invoice wasn’t ready, so I’ll get it tomorrow and report back.
chassis (08-28-2024)
#460
6th gear vibration solved - it was the transmission mount
This is the promised ”report back” regarding my 6th gear vibration odyssey. My car went into the shop yesterday and I just picked it up. I am tentatively happy to say that it seems the car is fixed. I say “tentatively” because I haven’t had a real chance to critically test it. But on the high speed, interstate drive home I didn’t feel the vibrations that used to affect the car. Later this evening or tomorrow I’ll drive it some more under more controlled conditions.
For those of you whose car suffers from excessive driveline vibrations, especially in 6th gear, I sincerely hope the above repair explanation helps you to resolve the issue in your car. Of course, each car is different and whatever caused my 6th gear vibration might not be the fault in another car. But even if the transfer case is at fault in some circumstances, at least now we know the transmission mount can be the culprit.
The following 3 users liked this post by LSR:
#462
Thanks @LSR for your response and glad to hear it’s resolved and I can certainly imagine the feeling.
Does anyone know if the same transmission mount is used across all models including the v8s and if the new part (number) has been superseded by the old one, which may suggest possible improvements?
#463
The following 2 users liked this post by LSR:
Greyphantom (08-29-2024),
Ironman88 (08-29-2024)
#464
This is a further update to my above posts. I've now driven my '22 base Cayenne over 100 miles since picking it up from the shop. This is a different car from the one I've driven for the past 20k miles ... the vibrations in 6th (and to a lesser extent in the other gears) are gone. So, what was the cause? Forum members have hypothesized about the cause, some saying the transfer case and others the transmission mount. The answer, at least in my case, was the transmission mount. Here is what my repair invoice says. Kudos to the tech for (a) recognizing that the car was not driving "normally" or "as designed," and (b) his tenacity in testing the car, finding the cause, and solving the problem. I'm going to give the tech (whoever he is) and my SA a big "thumbs up" when I complete the soon-to-arrive Porsche satisfaction survey. Here's the invoice explanation:
LSR (08-29-2024)
#465
Thanks @LSR for posting the invoice.
Color me skeptical that the transmission mount is the solution to the root cause.
Fresh rubber anywhere on the car always and without exception makes an improvement.
The root cause of vibration is…vibration. Rubber does not create vibration but rather attenuates it. You have a fresh new attenuator but the source of the vibration has not changed.
The source of the vibration is without question the driveline. Nothing in your driveline, rubber mount excluded, has been changed.
