Ordering base cayenne. Questions on ACC and Rear seat entertainment
Hi,
I am in process of building a base cayenne. I have a few questions about some of the options.
1. Do you get forward collision warning and possibly braking as well, without adding the adaptive cruise control option?
2. Can the rear seat entertainment system play DVDs? Is the system capable of playing blu rays?
Thanks!
Thanks!
Originally Posted by raoden
Hi,
Thanks!
Thanks!
2. Sorry, don't know.
Thanks for the response. Looked at the US website carefully after seeing your post. It does state "The standard collision and brake assist" So I assume it is standard. I was considering ACC just to get collision warning and braking. But if it is standard I would rather spend the 2K on something else. I am meeting my SA to finalize my build tomorrow. Will check with him about this and the rear seat entertainment as well.
Just wanted to update the post. I did meet with my SA and he kept insisting that Collision warning and Braking comes only with ACC. To his defense the website is a bit confusing. So I insisted he check with someone else. They called some regional Porsche guy and he confirmed that the front camera does Collision warning and Braking and it is standard. Apparently the radar on ACC can be used as a fallback in case the camera is not functioning fine. I ended up not getting the ACC.
On the rear seat entertainment front it can play DVDs but it can't take Blu Ray discs, which I have tons of. In the end I decided the cost was not worth it especially when it can't play Blu Rays.
My build is in, with a tentative delivery date towards the end of January.
Five months have passed since the "Warn and Brake Assist" questions were raised as compared to "ACC" option. Is there any current information that addresses this? I want the emergency braking, but the Porsche site offers no explanation....is the ACC a more effective / aggressive feature? Is the standard Warn and Brake sufficient?
(See....some of us do use search :-) ... ).
Here is the Euroncap rating for reference. There is no video for auto brake but clearly they have tested it.
https://www.euroncap.com/en/results/.../cayenne/29116
Think I'll save $2K & avoid ACC....would rarely use the cruise aspect.
I think I can answer this question.
All new models are standard equipped with collision warning and brake assist. Collision warning just uses the multiple-point-distance-sensor to monitor nearly objects(up to a few feet). It will give you a beep sound when the object is getting too close. So, Since it can only handle short distance, even just a big stone in the ground can sometimes trigger the warning. Brake assist won't brake itself automatically, it only enhances your braking, so, you will have to press the brake first, and the car will increase the braking force when it senses possibility of collision.
ACC equips with long distance LADAR that can sense all car/pedestrian interaction meters away. Hence, it can do slight turning, acceleration, deceleration and emergency auto braking. Also collision warning is more advanced. it will actually give a verbal warning of collision.
So, Only ACC can do emergency auto braking.
